2005 Chevrolet Silverado Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
04 Tahoe AC blows hot air on drivers side but resets if restarted
04 Tahoe AC will start up blowing cold and after a minute or two it will turn to blowing hot air on drivers side and cold air on passenger side. I can turn the vehicle off and restart and AC blows cold again.
Jeff Armer
Level 3:
  • Chevrolet Master 15,575 Answers
  • Posted on Mar 09, 2015
Jeff Armer
Chevrolet Master
Level 3:
Answers
15575
Questions
Helped
7111831
Points
73899
A educated guess I would have to say there is a problem with HVAC control module ! electronics you know ! But that's not the way to do things ! There could be codes stored in the module. The Chevy dealer my have a reflash bulletin for this problem . Then can reflash , reprogram the control module ! The first place to start is checking for codes in the HVAC module.
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal.
Air Temperature Sensors The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
Ambient Air Temperature Sensor
Inside Air Temperature Sensor Assembly
Inside Air Temperature Sensor Assembly-Auxiliary
Upper Left Air Temperature Sensor
Upper Right Air Temperature Sensor
Lower Left Air Temperature Sensor
Lower Right Air Temperature Sensor
Upper Air Temperature Sensor-Auxiliary
Lower Air Temperature Sensor-Auxiliary
A signal and low reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40?° to +101?°C (-40?° to +215?°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside air temperature sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
If the HVAC control module or auxiliary HVAC control module detects a malfunctioning sensor, then the control module software will use a defaulted air temperature value. The default value for the ambient and inside air temperature sensors will be displayed on the scan tool. The default value for the duct air temperature sensors will not be displayed on the scan tool. The scan tool parameter for the duct air temperature sensors are the actual state of the signal circuit. The default action ensures that the HVAC system can adjust the inside air temperature near the desired temperature until the condition is corrected.
The ambient air temperature sensor mounts underhood and can be affected by city traffic, by idling, and by restarting a hot engine. Therefore, the HVAC control module filters the value of the ambient air temperature sensor for temperature display. The ambient air temperature value is updated under the following conditions: Or you can just buy a new control module an hope that it fixes it. $89.00 at www.partsgeek.com
Search from over 10 Million Auto Parts
1helpful
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
1helpful
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
No heat from vents
Heater blows cold?
These will help.
Thanks.
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
1helpful
2answers
2004 Chevrolet Tahoe Heater blowing cold air on Driver side
bad control swicth or block air flow on driver side
3helpful
Drivers side AC will blow hot air.
the blend motor on the vehicle is probably bad
1helpful
04 Chevy Tahoe Climate control issues.
HVAC control head problem or it is the air Temp Control Valve problem. THe control head is the one with the buttons and knobs and the control vavle is located on the HVAC carrier assembly underneath dashboard (two of them one on left and one on right in center). This is a job for someone who has knowledge of HVAC and electrical on a GM vehicle.
2helpful
3answers
Raer a/c works but front blows hot air on my 99 tahoe
I just took my 04 Tahoe in for the same thing and it was the a/c actuator.
61helpful
3answers
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
