Question about Canon FAX-L350 Plain Paper Laser
Rec . paper jam
I am getting rec paper jam alarm intermittendly.. even though physicallythere is no paper jam
  • 4 more comments
  • LALITMANN
    LALITMANN Dec 18, 2013
    YES. THAT'S RIGHT
  • LALITMANN
    CAN YOU HELP ME.
  • LALITMANN
    THANKS.
  • LALITMANN
    how to check the rollers. any advice
  • LALITMANN
    Fault was in tray. working now. THANKS.
  • Anonymous Mar 25, 2014
    Paper jammed and after removing paper printer starts up displays error 5100 and stops
  • 21 Answers
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Posted on Dec 13, 2007
  • LALITMANN
    easy way to clean rollers
I find that if you have checked paper and there is some still in it then you just need to open and shut all sections of fax machine and it will then start up again and the red symbol will go off
Posted on Feb 19, 2008
  • LALITMANN
    it says open printer cover
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
I am getting rec.paper jam no paper jammed though
Open back door, clean feed roller very well, and open and close upper cover.
May 28, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Supply rec. paper when i insert paper then rec. paper jam
Your copier feed roller clought is not active wash it and then solve
Jun 11, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jam
Open the paper tray and remove the first couple of sheets of paper - If the paper tray is fully loaded leave it half full.
May 21, 2009 | Canon Office Equipment & Supplies
Rec paper jam message.
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon Laser Class 8500 Printer
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
Ir 1600
That code indicates a laser problem. You can check the door switches on the front of the machines as well as the left lower door.
Jan 25, 2008 | Canon imageRUNNER C3200 Copier
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon FAX-L350 Plain Paper Laser Logo
449 people viewed this question
old marine
old marine
