Question about Dryers
GE Dryer DDE7200SBLWW doesn't dry quickly
I have an older dryer which heats up fine but the clothes do not dry on the first cycle through. They stay damp, takes about three times to get them dry. I've noticed a little leaking out of the door, which i believe is just the sealant on the door that needs to be replaced there but I dont think that would fix the drying problem. Any suggestions?
  • rduke Dec 13, 2007
    thanks! i'll check that out later today.
  • 126 Answers
It sounds like it could be your vent turn dryer on go outside and feel your air coming out of vent if not a good air supply clean your venting system
Posted on Dec 13, 2007
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
GE Dryer DDE7200SBLWW -- dryer will dry on high heat for non permanent press clothes, but when you set timer and selector to Permanent Press it will not heat. Is this a thermostat issue or is the timer...
This dryer has 2 different cycle thermostats One is for 135f and the other is for 125 f. Maybe the 125f tstat is faulty? I would check that before ordering a timer. A good cleaning might do it also. Clogged dryer will overheat you know.
Sep 19, 2013 | GE Dryers
Dryer doesn't dry
You may need a new heating element.
Mar 28, 2012 | GE Dryers
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 11, 2011 | Dryers
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 30, 2010 | GE DBSR453GB Gas Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
348 people viewed this question
Top Dryers Experts
