Question about Clarion Car Audio & Video
Require the pinout for a 8 pin plug
I have a suzuki grand vitara(07) with a Clarion PS-2996D-C head unit with a 6 stacker attached. Between the normal power/speaker plug and the stacker plug, there is a 8 pin socket. I have found one of the pins to be the telephone mute.Can you tell me the pinout for the other pins as I would like to have my handsfree car kit use the stereo speakers.
Regards
Grant
    Top Expert:
  • Clarion Master
  • 2,931 Answers
I don't really know. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
require the pinout for a 8 pin plug - helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_12.png
Posted on Feb 10, 2018
  • 111 Answers
SOURCE: clarion drx9675z head unit connector
Go to pacparts.com
They are authorize parts dist. for Clarion
Posted on Feb 01, 2008
SOURCE: clarion drx9375r
Ask your friend Donald, maybe he could help you....:)
Posted on Sep 30, 2008
tech48
  • 624 Answers
SOURCE: speaker hookup
Use the speaker wire outputs on the wiring harness on the back of the radio. The RCA outputs are for using an external amplifier, so you do not want to use them. The speaker wires should be color coded. The front speakers are normally grey and grey with a black stripe for one side, and then white and white with a black stripe for the other side (left and right sides)
The rear speakers are violet and violet with a black stripe and the other rear is green and green with a black stripe. All the solid colors are the positive speaker output and the wires with the black stripe are the negative speaker outputs.
These speaker outputs are on the same harness as the power connections to power up the radio. I believe that it has more than 10 wires on it. I am not sure what socket you speak of that is 10 pin and has speaker outputs. The speaker outputs alone are 8 wires, so the harness will have more than 10 wires. It also has the yellow wire for constant 12 volts to keep memory, the red wire to connect to 12 volts when the vehicle is on, and the black wire for the ground. Then it should also have a blue wire for use with an external amplifier to turn it on or to use for a power antenna to turn it on. You may also find several other wires on it like the orange for illumination and brown for muting the radio when a phone is in use. Those last few wires do not need to be used unless you want them for a specific purpose.
Posted on Jan 24, 2009
  • 21 Answers
SOURCE: Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Posted on May 19, 2009
  • 87 Answers
SOURCE: clarion wiring db346mp rear speaker pins
Sounds like you are missing one of the leads. You will probably need a new harness OR try any local stores to see if you can find the same length pin that snaps in to place on the molex plug
Posted on Jun 02, 2009
What is the bypass code for a Clarion VX401
factory car radios have codes.
never aftermarket ever....
so is this a stock car radio or not?
if stock SUZ radio? there are only 6 ways, posted over 100 times.
6 ways on all cars made
http://www.fixkick.com/power-elect/Keep-Alive/keep-alive.html#radio
#6 is very very risky.... leaving 5 other ways.
Oct 22, 2015 | 2011 Suzuki Grand Vitara
By pass code for clarion VX401
asked 2 time, why ask twice.
its answered backup one and read.
its been answered here 100s of time, or 22million times on google.
ever do searches?
Please advise code for Clarion DVD Player, Model PS-3220D-A for a Suzuki Grand Vitara. Thanks
factory radios need code (pass word) to operate if the
cars battery goes dead or is disconnected.
no year car stated...
this question has been asked like 1000's of times here. (or millions world wide, google that)
and the answers is same on all cars. made.
the operators guide answers this, but here are all choices.
"my radio is bricked"
6 ways? pick one?
Jun 22, 2015 | Suzuki Cars & Trucks
How to reset Suzuki Grand Vitara 2006 after I punch in wrong code more than 6 time after I took out a radio compartment to fix it . The car start and shut off when one s I gear to D or R
Try disconnecting battery. Then re-connect the battery and type in the correct code.
You could try the factory default code, which is 0000. There is some confusion whether Suzuki/Clarion produces these audio units with a preprogrammed lock code (0000) or not, but its worth a try. If a previous owner has set their own personalized code then there is absolutely NO way for you to work around it. The audio unit will have to be removed and returned to Clarion for reprograming. A Suzuki dealer can help you with this, but they can not unlock the radio, only Clarion has that ability.
May 15, 2015 | 2006 Suzuki Grand Vitara
Need am manual for the head unit and 6 stacker
Have a look here >>>>>
http://www.clarion.com/jsp/search/ProductManuals.do?country=us&language=en
Aug 23, 2009 | Car Audio & Video
Car Audio & Video Logo
215 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
