Question about Standard (CRT) Televisions
Zenith 32" tube tv going out?
Hi all,
Great site. I have a Zenith 32" SL3285BG tube set. Its approx. 12 years old. What is happening is when you first turn it on it has a purple-ish- pink
picture. After about 10-15 minutes, the picture returns to normal. Seems after it heats up the picture is ok again. Do you have any suggestions as what component might be causing this and would it be something I can replace?
As A side note, about 5 years ago the set had a bunch of white horizontal lines on the screen. Finding info on the net, I bought a ESR meter (dick smith), and end up replacing eight capacitors. I think they were on the power supply board. That fixed the problem. I have worked on this set before and would tackle it again with the right guidance. Thank you for any assistance!
  • 21 Answers
Re: Zenith 32" tube tv going out?
This is classical intermittent condition. These are caused by loose wire, cold solder joint, corroded terminals or such type of malfunction. They are extremely difficult to find, but easy and cheap to fix once you find them.
Probably only 50% of them are ever found; most of them are "lived with" by finding a proper slap on the back of the set, a book or magazine under one corner or something that puts enough torque or twist on the chassis to get the picture working, then just carefully leave it in that position and don't bump it again.
If you want to really find it, you will be better off doing the sluething by yourself than taking it to a shop because their time is money and the cost of labor to hunt it down may be expensive. (With luck it might be found quickly, but on average it takes along time even for a trained expert tech to find them).
Posted on Dec 13, 2007
0 characters
3 Points
My Tv has sound but no picture. It is 12 years
may your picture tube in bad condition or no filament voltage
Feb 25, 2010 | RCA F36674ET 36" TV
Colors going bad on my tv?
The picture tubes in Zenith sets (I assume it's a Zenith since you posted this with a Zenith heading, although it's also true for any set this old) were only expected to last around 7 years. Your description makes it sound like you are missing green, or that the green is just way low. This is a common sign of a bad picture tube. There are other possible causes, but tube failure is the most likely. The low replacement cost for small TV sets makes repairing this one uneconomical.
Get rid of the set and treat yourself to a new one.
Jan 25, 2010 | Zenith SY2068DT TV
Too much green on tv screen
how old is the tv. did this happen suddenly or over time? also try adjusting tint that might work
Jul 23, 2009 | Standard (CRT) Televisions
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
TV Turns green and shuts off and less than 5 seconds.
In that TV its usually a bad picture tube. The green element of the tube is shorting.
Mar 13, 2009 | Zenith D32D51 32" TV
Is this a digital tv? can i get a manual?
if the set is over 2 years old it more than likely wont be a digital set. press the AV button that should switch you between digital and analogue if the set has digital in it
Mar 08, 2009 | Zenith B32A24Z 32" TV
I do not have a Zenith B25A02Z TV. What I do have is a 1988 Zenith Color TV SE2517P. I called a local tv repairman and discussed the problem over the phone. He can take a look at it if we bring it in (service call to the home cost $100 just to show up). He said it was worth fixing since he thought it was only the sound. We have a great picture. He charges $20 to look at it but we have to leave it. He lives 20 minutes away one way. We think it is worth the trip if we can get it loaded into our minivan. We live in western NY where the weather can get pretty ugly many days. I will post the solution later when I know. FYI
Dec 30, 2008 | Zenith B25A02Z TV
32 wega trinitron
surprised it went 12 most 8-9 not Worth the fix
Apr 17, 2008 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Zenith A32B43W color problem
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Oct 15, 2007 | RCA F32450 32" TV
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
Standard (CRT) Televisions Logo
859 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
