Question about ViewSonic VP230mb 23.1" LCD Monitor With Speakers, Black
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Viewsonic VP230mb 1 week after warranty ended, the monitor quit. Power light comes on for about 1 sec., then goes off, no screen. Tried new cords, no luck. Hooked up another monitor and it works fine, so it is not a computer hardware problem. Got any ideas how to fix??????
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Make sure the monitor is set for the correct input
Posted on Jul 21, 2017
SOURCE: Monitor Blinking
This is a Common problem MOST if NOT ALL, problems like this with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe
Posted on Jul 30, 2007
Riziel
  • 116 Answers
SOURCE: LCD Monitor has no video
Sounds your monitor has either blown a backlight or the inverter board is bad. Either way they can both be replaced, but tracking down the parts will be a bit difficult. But your LCD Monitor is in trouble! Sorry!
Posted on Nov 26, 2007
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
SOURCE: Viewsonic VA1912wb power goes off
xZAxZC
Posted on Sep 03, 2008
SOURCE: viewsonic problem
I RMA'd this probablem as well. They asked the usual questions -- try it alone, check the connections, are you using VGA or DVI... blah blah. Eventually they could give me an RMA.
They have customer support via phone on Sundays in the US, which is nice. Total time from calling to RMA was about 20 minutes.
Posted on Sep 14, 2008
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
ViewSonic VP230mb 23.1" LCD Monitor With Speakers, Black Logo
87 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
