Question about OKI B4100 Laser Printer
Error LED blinking after paper jam, won't print
Hello, I have a problem with my Oki B4100. After I removed the sheet after a paper jam it's now constantly blinking with the error LED (red) and won't print anything. In Windows it shows the printer is ready, when I send something to print windows tells me it is printing but the printer just stays still and blinks with that red error light.
I've tried turning it off and on again, tried removing the cartridge and putting it back again. No luck.
What can I do ? Am I missing something?
  • SAVESKI Dec 14, 2007
  • 3 Answers
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Posted on Feb 28, 2008
  • 3 Answers
You need to download the utility from oki for this printer. This is seperate from the driver. The utility then tells you what is wrong ie paper jam ,out of toner etc. The paper jam light serves as a warning light also so it might not only be a paper jam that activates it.
Hope this helps
Posted on May 08, 2008
Indicator is not steady it is blinking.it is not responding to print commands.
Hi
If printer Leb is blinking then you have error in printer check the mention below note.
1) Check the printer door, all door close the properly
2) Check the paper Jam, remove the jam paper.
3) Check the cartridge level, change the cartridge.
Cheer
Jul 19, 2011 | OKI C7350hdn Led Printer
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
How to clean an OKI B4100 (new toner, blotchy printing)
Open the cover, remove the cartridge and vacuum carefully the interior. Clean the leds when the cover is open and it should work.
Apr 04, 2010 | OKI B4100 Laser Printer
OKI B4100 paperjam warning
Acording your explained you need do
1) clean the input tray roller surface, to make sure it has enough grip force.
2) looking for a sensor around the roller rear, it could be cause the paper jam there, because if the sensor does not detect any input paper go throug there then should be stoped at roller rear.
3) if you find a optical sensor there, please use a slft cotton stick to clean its surface. (maybe open some cover needed)
hope you fix it , ask me any time please!
May 17, 2009 | OKI B4100 Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
B4100 - Yellow Light
U can have stuck a little piece of paper, that it mess whit some sensor. Try to open the Oki, push the drum unit out and watch if there is no paper stucked.
Nov 26, 2007 | OKI B4100 Laser Printer
OKI B4100 paper output. Frustrating!
If your oki is like the 4300 we use it may be as simple as making sure the extention for the back tray (where the paper is printing to now) is pushed all the way in. This actually selects the tray option. If this tray extention is pulled out at all, your printer will print to the back tray.
Oct 25, 2007 | OKI B4100 Laser Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI B4100 Laser Printer Logo
927 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
