Offhand, you description would indicate an about to fail component in the vertical deflection circuitry; to be more specific the pump-up capacitor. A most likely possibility is that the capacitor have started to dry up or leaking and therefore would require replacement. This would be C407, a 100uF / 35V electrolytic capacitor. Please note that this component has a polarity and the replacement must be soldered back in in a similar orientation.
Since the unit is open, might as well check conditions of C406, C408 and C409 (unlikely but worth the efforts).
Options then are:
consider a DIY (do-it-yourself) repair if and only if very familiar with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe working practices with high voltages. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
should you be uncomfortable with a DIY, perhaps your best bet would then be to seek the services of an authorized Toshiba Service Center (specially if still under some form of extended warranty) or a qualified professional.
Good luck and thank you for asking FixYa.
Comments:
Sep 19, 2009
- Unfortunately, Service manuals are not readily available as free download. However, for a fee, a copy is linked here.
I have the same issues with the white lines at the top of the television...however, I also have an...
(More)
I have the same issues with the white lines at the top of the television...however, I also have an issue with the television "dripping" almost continously! A vertical "drip" almost on every channel! Would this be due to the same "cap?" OR, something else? Thanks for any advice or help in advance!!!!
Horizontal line at top. They are around 8 line space by .25 inch. Some station will emit signal in...
(More)
Horizontal line at top. They are around 8 line space by .25 inch. Some station will emit signal in wide screem them it wont show. So it is only at top of screen. Is they a way to enter some type of menu to adjust. Or will I need to go back 10 yrs and play inside the TV. It is a Toshiba, model 27af43
i just got a toshiba tv...27af43..27". but i do not have the remote.pl help me as to how can i...
(More)
I JUST GOT A TOSHIBA TV...27AF43..27". BUT I DO NOT HAVE THE REMOTE.PL HELP ME AS TO HOW CAN I SET CHANNELS...ETC. THANKS
What causes the picture to shrink and have black lines on each side,and the picture to be Jumpy ? Is...
(More)
What causes the picture to shrink and have black lines on each side,and the picture to be Jumpy ? Is there a recall we don't know about,or an easy solution or part to fix this problem? What can I do? THANK YOU
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
