Question about Kenmore 62802 Electric Dryer
Kenmore dryer my clothes just keep rolling up into a ball...I make sure they are seperated and shook out...then the dryer just rolls them all up together into a ball and of course they don't get dry
  • Anonymous Mar 15, 2014
    they roll up and come out all wrinkeled
  • 126 Answers
Could be;
belt slipping
over loading
tumble veins inside drum broken
Posted on Dec 13, 2007
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
Clothes roll into a ball on matag dryer
THE DWADDER
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tightwad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets.
Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to
unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet. In order the fix this problem the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed into the dryer. Once the dryer is started the blanket or sheet will wrap around the device allowing a space to be in the center of the blanket or sheet. With the space that is created by the
Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to
unwad your blankets and sheets half way between the drying cycles.
The Dwadder will save you time and money. It can save up to 30 minutes off your drying time. This will save you energy. You will save time and worry less about your blanket or sheet not being completely dried when the drying process is finished. As an added feature the HDPE plastic ball opens to allow for a dryer safe fragrance to be placed inside the ball. This will reduce the use of dryer sheets.
We would love to have you as our customer. We know that the Dwadder will save you time, money and
lower the frustration of drying laundry.
For more information and
videos on how to assemble and use the Dwadder come visit us at
WWW. Defuturesolutions.com
http://www.defurturesolutions.com/
Jan 10, 2013 | Dryers
Have a 2780 dryer stackable that is leaving grease/burn streaks on my clothes. it seems that lower front of drum is not sitting flush. there is a gap against the wall where clothes or dryer sheets get...
you need replace drum support roller,an check to make sure drum hadnt cut into back are the front of dryer the felt that drum roll around on may allso need be replace.some ge dryer have single bear it roll around on it attack to back of the dryer drum
Feb 28, 2018 | GE WSM2780DWW Unitized Spacemaker Washer...
I have a kenmore electric dryer #86671100 it seems no air is exiting the dryer it gets warm, and the drum rolls just no air passing. I checked the screen it is clear what next?
Open the door, keep lid switch closed.
start dryer, does the drum roll? if so then
your fan on the motor may have broken
if drum does not roll you have a broken belt
either way you need a tech.
May 26, 2010 | Kenmore 22422 Top Load Washer
Rollerball on Wireless mouse keeps getting gummed up. Cleaning done frequently but need to open mouse to get inside cleaned ?
The Apple wireless mice aren't made to be disassembled, not even by techs. If you disassemble it to clean it, you must glue it back together.
The best way to clean the rollerball is to remove the batteries and roll the ball upside down on a cloth soaked in alcohol. Be sure to roll the ball alternately depressed and not depressed for the best cleaning, and roll it in all directions.
When this no longer works, you can either attempt to clean the ball yourself at your own risk, or purchase a new mouse.
Nov 25, 2009 | Apple Computers & Internet
Weak Dryer exhaust
I have seen the blower unit in those machines split where the impellor is fastened to the shaft. This causes the fan to not spin fast enough to move a lot of air.
Mar 04, 2017 | Dryers
Clothes roll into a ball on kenmore gas dryer #11062202101
Just get the filter out and remove the 2 phillips screw init's housing on top. Then use a putty knife to press against the spring clips that hold down the top Then just roll the drum around to the top where the holes are to reattach the baffle, get some screws and put it back.87656db.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 15, 2008 | Kenmore 63942 Dryer
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore 62802 Electric Dryer Logo
71 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
