Question about Alcatel Newbridge MainStreet 3600 Multiplexer
Mainstreet 3600 cpss does not work
My old 3600 suddenly does not respond to cpss or vt100 terminal,
is it possible to reset the whole 3600 to default ?
  • mb2745 Aug 01, 2008
    I think my problem may be with the cables that I ma using to access the serial port. Can you provide the cable pinout for accessing the 3600 via the serial ports
    Problem Solver:
  • 13 Answers
VT100 RJ45 DB9 1 8 2 7 3 2 4 3 5 5 6 4 7 6 8 --
Posted on Apr 07, 2010
No tengo el manual en electronico por favor guiarme sobre el mismo en version español
Posted on May 28, 2008
Reset 90-0667-05 to vt100
If you log on to SP1 using VT100 and you get garbage the port is properly set for CPSS and you will have to use a craft interface to log on talking CPSS to the node. The S1 switch on the control card is to reset the database on the node, but you can also use this to reset the SP1 port back to VT100...be very careful doing the following procedure as you can delete the database. Power down the node and press and hold in S1 then power up the node still pressing in S1, look at the the display it will after going trough it's start up process display a "0" ...release S1 and press S1 again....this will reset your SP1 to VT100 and you will be able to log on again. "0" reset SP1 and if it display a "1" and you carry on you will delete the database. As I warned you the "1" will delete the database, if for some reason you are stuck on "1" just power done the node without pressing S1 and it will restore as previous setting....good luck!!!
Sep 16, 2014 | Alcatel Newbridge MainStreet 3600...
After a reset 90-0667-01 Controller Database to default setting can not have access to administrate
If you reset the control card to a "0" the SP ports will default to 9600 VT100. Make sure that you connect on the back plain SP1. Reset with"0" will only reset the SP ports. Reset with "1" will default your database and all connections will be lost. Access will be Level-5, Password-mainstreet.
May 03, 2011 | Alcatel Newbridge MainStreet 3600...
What is cpss used for?
CPSS : Control Packet Switching System
CPSS used for like SNMP management...
Nov 18, 2010 | Alcatel Newbridge MainStreet 3600...
CPSS doesn't seem to work
You cant connect CPSS to TS0 IT is reserved tried on TS 30
Jul 21, 2009 | Alcatel Newbridge MainStreet 3600...
CPSS CONNECTED TO SP1 OF DXX CHASSIS
this is just for to appear the node on NMS. so if you are having some problem with it you can change it but you will not see it on NMS.
Jul 07, 2009 | Alcatel Newbridge MainStreet 3600...
Can anyone please tell me how to check that which Control Card's IOS (Software) version I have ? Some one told me that Its like release 7 , 8 or 9. Plz tell me cz I want to upgrade my IOS .
When you 're login to system via VT100 or CPSS connection, top of the screen you can see easly the version of CTRL like 1117-H1-xx ...
I think 1117-H1-70 was the latest version for single shelf configuration.
ilker
Jul 03, 2009 | Alcatel Newbridge MainStreet 3600...
CPSS
Look at the previos response, I did explain it.....
Jun 13, 2009 | Alcatel Newbridge MainStreet 3600...
We have our all Nodes on our network . They are accessed by NMS at our HQ . But the problem is that When we locally want to access DXX Node via ANM , it is not accessed.Also DXX Nodes SP1 and SP2 are CPSS...
You don’t need to configure SP1 for CPSS, log on to the node via you NMS and change it to VT100, then log in using a hyper terminal session on you laptop. If the SP1 port is setup for CPSS you will have to install a dongle and you will need to set your ANM up for networking meaning that you will have to speak to the node via CPSS. The only time you need to communicate using CPSS on SP1 is when you want to backup the database.
Jun 12, 2009 | Alcatel Newbridge MainStreet 3600...
Can anyone please tell me What is the differenec between dedicated and shared CPSS connections ?
There are 4 Dedicated CPSS recourses on the control card, namely CPSS-1, CPSS-2, CPSS-3 and CPSS-4. These CPSS recourses are configurable at 64K 16K etc. Each CPSS recourses are dedicated to a specific node and can only be used once.
A shared CPSS recourse is exactly what it means, it a sheared recourse. This means you can connect as many recourses using a shared CPSS recourse.
Be very careful connecting to many shared CPSS recourses as this can over load the control card if too many is connected.
Use the four dedicated first and if more recourses is needed install a DCP card which house 31 more dedicated recourses
Can't access to alcatel 3600 node managment station from faceplat
SP1 is belong to VT100
Jan 09, 2009 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
703 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
