Take an electric hand held grinder with either a small carbide burr or grinding bit and grind away the rest of the head of the screw. This should release the handle so you can pull it off and then you should be able to remove the remainder of the screw. If it is a set screw holding the handle, grind the top of the screw flat and use a drill to drill it out.
Testimonial: "Thank you very much much for your help, im just going to give it a go now. Tony."
