Question about Sewing Machines
Tension Problems with Janome DC3050
I have a Janome DC3050 and it keeps binding on the bottom side of the matterial when sewing I have rethreaded the machine now several times and turned it off and back on the clear the settings. My machine is part computerized and some manual tension I have over 50 designes to pick from and they are all have the same problem what do I do? What do dose the dial that runs vertical do? It starts at 0 and goes 2,3,A,5,6,7,8,&9???? I have it on A what ever that means? Please Help!!!! Thanks
The tension seems to have just stopped working on my sewing machine, it stopped picking up the bottom thread for some of the stitching to leave a broken line and then stopped picking it up at all.... i have tried with different fabrics and changed the tension dial from 0-9 but the tread stays at the same tension the whole time. is there anything i can do?
Posted on Jul 18, 2011
If your machine is binding. It sounds like you have a threading problem. Check your manual and rethread the machine. The A is for Automatic tension I would not change that. I would also notify your dealer and see if you have thread under the bobbin case. All sewing machines should be serviced each year.
Posted on Sep 05, 2008
I have a Janome sewing 521 sewing machine and the bottom thread keeps jamming. It will sew approx two stitches then pick up. Have rethreaded top and bottom thread s many times. Please help
indicates that the needle thread tension is not tight enough
disregard the tension settings
threead the machine correctly and before putting the thead in the eye of the needle pull on the thread
I foyu do not feel significant resistance to pulling the thread , thne check that the thread is between the tension plates or increase the setting up until you get that resistance , then thread the needle
Mar 07, 2018 | Janome Sewing Machines
Janome sewing embroidery machine starts and stops
Just a possible suggestion:
Most sewing machine problems are caused by lack of lubrication.
Maybe the tension is causing an error code.
Maybe you can try oiling the recommended lubrication points in the owner's manual.
Jun 13, 2016 | Janome Sewing Machines
My Janome 1600 keeps breaking threads
Is the tension too tight? Are the tension discs clean? Remove bobbin case, clean it and re-thread as this may be jammed.
Apr 26, 2015 | Janome 1600P-DB Mechanical Sewing Machine
My janome DC 3050 keeps showing bl when i make a button hole
BL stands for buttonhole lever,, it's to the left side of the needle bar,,just pull it down when you want to make buttonholes & when your finished making buttonholes,, just gently push it back up
Sep 20, 2011 | Janome DC3050 Computerized Sewing Machine
Where can I get an instruction booklet from for Janome DC3050
Free PDF manual for your Janome DC3050 at http://content/janome.com/ Jimmy
Jul 13, 2011 | Janome DC3050 Computerized Sewing Machine
THREAD BINDING UNDERNEATH
try rethreading it with foot up then let foot down and thread needle make sure there is tension on thread with foot down. if that is not the problem check the needle maybe in backwards.
Jun 21, 2011 | Janome Sewing Machines
Am I to oil the Janome DC3050? If so, where?
Hi Betty:
The only place I am aware that the user can oil their machine is in the bobbin race. Take our your bobbin and look for a tiny white wick usually right in the center. Apply ONLY 1 drop of oil.
Mar 12, 2011 | Janome DC3050 Computerized Sewing Machine
How to clean a janome DC3050 sewing machine
Just keep the bobbin case area perfectly clean and lightly oil with WD40
Jun 23, 2010 | Janome DC3050 Computerized Sewing Machine
Brother LS-2125 - stitches forming loops on the right side as a sew
acing you has loops on it then it is the bobbin tension which is incorrect or the bobbin has been threaded wrongly. A good way to test tension is using contrasting colours top and bottom. Rethread your machine and tighten up the bobbin tension screw if needed.
Jun 15, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Tension
Might sound simple, have you just tried rethreading it a few times? The bottom bobbin thread might be stuck on something.
Dec 03, 2007 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
519 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
