Question about Dell Latitude C400 Notebook
Toshiba satellitw cdt4070
Works ok, till I use it unplugged and just run with own baterry. Next time, it won't turn on again. Tried and tried, removed the battery and just plugged, no help. Pls help.
    Master:
    Sergeant:
  • 482 Answers
The battery cant hold a charge, replace with a new battery. ebay has a lot of them cheeper.
Posted on Dec 20, 2007
Samsung RV510 notebook won't come on
Ok, then, try this:
1. Unplug your power cord,
2. Remove Battery,
3. Press power on botton for 3 sec.
4. Now plug battery again,
5. Locate F8 key (it is a single key, at top of your keyboard)
6. Press power on boton, and as soon as screen shows manufacturer logo (or memory count), start to press F8 key repeatedly until a menu display,
7. Select "Secure mode"
8. When the system starts, clic on "Start" boton, and type "recovery"
9. At new window click on "Open System Restore"
10. At new window, cick on "next"
11. From list, select a date prior AVG uninstallation.
12. Follow wizard instructions.
System will restart several times, and if you are luky, then your system will work again. And, PLEASE, Do not install Symatec any more. Try Essentials:
http://www.microsoft.com/en-us/download/details.aspx?id=5201
Sep 20, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Runs fine then all of sudden it won t start
remove the pump and check for sediment in the pick up gauze filter ,if bottom of tank clean then check the connections on the multiplug ,if ok then drive it till it stops and then check it again as the fault is their but its finding it at the right place at the right time
Jun 16, 2012 | 2006 Chevrolet Uplander
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My laptop was left with the top down and turned on. It was plugged in and when I opened it to use it again, the screen remained black. I tried using different keys but nothing would happen. I unplugged...
Hi, Nan.
Disconnect the power adapter, flip the laptop, unlock and remove the battery. Then, reinsert and lock the battery, connect the power adapter and try again.
Hope this helps.
Jul 30, 2011 | Toshiba Computers & Internet
Toshiba laptop running w7, when i turn laptop on it goes straight to start in safe mode or normal, tried safe mode but get a continuous beep, then it switches off, then turns itself back on again, with the...
Thats because your lap top needs to be reebooted in a format to reconfigur itself unfortunatly its not doing that please! do an early system restore to when it was working and save those settings for the next time this happens ok! and save all your current files just in case you need to wipe your whole drive to origibal settings ok!
Mar 26, 2010 | Computers & Internet
Intermittent pressure building
The check valve is easy to test. All that you have to do is run the compressor till you have some pressure in the tank, 50 ~ 60 lbs will do, then remove the air discharge tube at the check valve installed in the tank (the brass valve). Spray soapy water into the valve. Tiny leak is ok, rapid leak replace valve with generic valve from www.grainger.com . Most likely problem is worn cylinder or reed valves in the head. To check cylinder, unplug unit and (oilfree compressor) remove cover to expose the crank. Push the piston all the way up and check for scratches on the upper part of cylinder. If scratched, replace with kit# K-0650 available at www.toolpartsdirect.com. If cylinder is smooth all the way up then problem should be the reedvalve plate in the head. The reeds could be held open with debris or broken. Clean or replace as needed. Good Luck and email if you have questions about the repair. (Oil in crankcase type compressor will not have cylinder problems)
Feb 25, 2009 | Porter Cable Air Tools & Compressors
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Sep 15, 2007 | RCA HD52W58 52" TV
TV doesn,t turn on
the power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Feb 17, 2007 | RCA P46812BL 46" Rear Projection...
Dell Latitude C400 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
