Eberspacher I require the running instructions for the eberspacher water heater
  • Anonymous Mar 31, 2014
    It is the old manual timer with a clock display
  • 625 Answers
Go to the eberspacher site in germany.
Posted on Dec 14, 2007
Does the water heater and furnance run on gas and electric?
If the units are in a RV then yes, they both may run on gas and DC (battery power). The furnace requires gas to provide heat and DC power to run the fan. A water heater may be gas or electric, but if gas, it requires gas to heat and DC power to ignite. If the water heater is electric it requires AC power to heat.
Oct 15, 2015 | Water Water Heaters
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
My motorhomes Eberspacher combitronic heating no longer works on 240v although still heats water and heats on diesel.
Hi l had exactly the same problem with my combitronic, tried virtually everything, asked & took my motorhome to several places found one that could find the fault. Apparently there was a break down of a wire under the sheathing stopping the heating working on 240v. Agency supplied if required.
Jul 23, 2012 | Dryers
Hi i have just fitted a eberspacher d4 to my boat it starts up well but after 20 mins it shuts down but will fire up again after a few hours ?
it could be that the fuel filter is cloged up or pump but theres defo a fuel problem is there any kinks in the fuel pipe i had a car that was doing same thing
Feb 19, 2012 | Heating & Cooling
Code 11
Before calling service technician, open following links for Rheem troubleshooting resources including error codes.
Error codes are considered start-point for troubleshooting.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error 11 is no ignition.
This problem can probably be solved by routine yearly maintenance shown in instruction manual which recommends: Yearly cleaning, adjustment and inspection of burner and combustion parts.
The yearly maintenance would check incoming gas supply, venting, wiring and grounding, and burner and ignition parts.
All gas water heaters today require same maintenance: tankless require yearly, and tank-type require periodic (1-3 years)
Jul 03, 2011 | Rheem Tankless Hot Water Heater...
Need instructions on how to drain and flush.
You posted under water heaters.
Always let a water heater cool off before draining.
Hot water can cause serious burns. Immediately put burned area into cool water.
There are different types of water heaters, and each might drain and flush differently.
Open following link for typical gas and electric tank-type:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
To drain and flush tankless, it can be called de-liming tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Be sure to read tankless manual for instructions and advisories, and required maintenance.
If you have boiler, or indirect water heater, solar water heater, or RV heater, the instructions above may not apply. be very careful with a boiler due to extreme high temperatures.
Add a comment and give more information about heater, for possible help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Water Heaters
Pilot will not stay light but will turn on and work properly
When having a problem with pilot and burner, the place to start is troubleshoot section in your manual.
Whirlpool is probably made by Craftmaster which I believe is a Rheem company, and Rheem makes a number of different models.
Some models have specific manuals and others have generic manuals.
Open Rheem water heater page and click on water that matches your water heater. On page that opens, click on tab that says 'specs' and then download manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
If none of those water heaters look like yours, open following link to help identify company website and download manual. Craftmaster website does not have instruction manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
All gas water heaters require periodic maintenance.
Some require yearly maintenance.
The burner parts require cleaning.
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/images/Clean-burner-250.jpg
http://waterheatertimer.org/How-to-install-gas-water-heater.html
May 01, 2011 | Whirlpool Water Heaters
Hi,eberspacher d4 airtronic prob,the power supply from battery was disconected whilst it was still running,so it didn't shut down properley,now it goes through the starting sequence x 2 but fails to start...
We have an Avondale Seascape Motorhome 54plate which has Eberspacher heating - (D4) - It strikes up and heats for about 1 minute - then cuts out and does not go again - have been to a garage who tried a new timer - without success - anyone out there with any idea to a solution- also estimate as to what it would cost
Feb 09, 2010 | Heating & Cooling
Heating & Cooling Logo
626 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
