Question about Sony VPL-CS7 Multimedia Projector
Lamp Cover will not close fully
The lamp cover is half open and half closed. I switch the projector on and the lamp indicator light flashes - the projector works for about 10 seconds and displays the output image on the wall but then the on/off button flashes green constantly and it stops projecting.
Is this easily fixed?
  • 563 Answers
Hi there
Your lamp is not properly inserted.
The lamp door should close easily if your lamp is in correct.
If teh lamp door is not closed properly then the mashine will keep on shutting down.
Posted on Apr 02, 2008
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
How do I fix Lamp/Cover flashing light?
There is a switch or a button that gets depressed when you close the lid of the lamp compartment. See if the plastic of the lid is broken or not hitting it right. Not screwed down right or the lamp is not seated all the way down.
Dec 20, 2012 | Sony Office Equipment & Supplies
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
The power light is red, and the lamp light is blinking red. can you help me. thankyou
This indicates that the lamp cover is not properly closed. Disconnect the mains power and carefully open the lamp cover, reseat the lamp and close the lamp cover taking care not to force it.
A fault of this type would be common after a lamp has been replaced, or at least removed for inspection.
Feb 21, 2011 | Hitachi CP-X200 LCD Projector
Replaced the lamp in my Dell 3200mp projector when the lamp indicator came on. After replacing the lamp indicator is off , but the lamp will not even attempt to light. Anything else I can check?
did the old lamp fail? Or did the lamp light just come on?
Firstly I would disconnect the mains and carefully put the old lamp back in. Test the projector. Then put the new one back in and test.
There can be problems with lamps not being seated correctly, and/or the lamp cover not being fully closed.
Post back for more help if required.
Dec 29, 2010 | Dell 3200MP Multimedia Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Jun 25, 2008 | Sony VPL CS5 Multimedia Projector
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Jan 15, 2008 | Sony VPL CS5 Multimedia Projector
Bulb Shattered...After replacement does nothing!!!!!
Did you get any anwsers as I'm having the exact same problem with my projector, the noise for few seconds, the light flashing...
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
Sony VPL-CS7 Multimedia Projector Logo
406 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
