Question about Toshiba Satellite 5005-S504 Notebook
Desktop Icons The icons keep flashing from one icons to other making' it impossible to select an icon. Also the "S" key repeats itself across the the screen just like it is stuck?
  • Anonymous Mar 23, 2014
    all icons in desktop are itunes icon
  • 883 Answers
Sounds like you have two stuck keys. The S key and the TAB key. Suggest that you disassemble keyboard and clean it with alcohol.
Posted on Dec 13, 2007
2 Suggested Answers
  • 48 Answers
SOURCE: Icons on desktop
The icons that flash are probably shortcuts that start with S. The S key is causing both problems most likely. There are screwed labeled with K or a unique icon. All located on the bottom of chassis below keyboard. Remove them and life up the keyboard. Do this while the power is off. Disconnect the ribbon cable from the keyboard and remove it. Power on the laptop and let it boot. Once its to the desktop you can see your result. Then all you need to do is pop out the S key and spray contact cleaner underneath rubber contact sheet. You may have to remove some screws.
Posted on Jan 07, 2008
How cna I hide all the Icon on my PC Desktop; nad how to unhide it again?
Hiding your desktop icons is a simple procedure. Use the directions below:
    1. Right-click on your desktop.2. Select Arrange Icons By.
    3. You will see a Show Desktop Icons with a check on it. Click it to uncheck it.
    4. To return your icons to the desktop, repeat steps one through three.
Regards,
Rahul
Jul 14, 2013 | Computers & Internet
Desktop
I think you need to click right on desktop ...and select ..view..and click the show desktop icons ..try it ..and let me know if this solve the issue ..
Good luck !
In case you reinstalled it clean ..and this is the first time ..or you erased teh icons somehow..you just need to make new shortcuts ..
For the system icons..just click right on the desktop ..and select properties...and under desktop ..select desktop icons ..or change desktop icons..it is a link on the bottom ...of the window..selecting it will open a window where you can select the icons..and click apply ..
For windows 7 ...click right on desktop ..select personalize ..and in the left of the window select change desktop icons..and same thing ...tick the cases..and the main icons will be displayed..apply and OK ..
for the rest ..you need to make shortcuts ..from the start menu ..all programs ..one by one ...by clicking right on the program execution ..and select send to desktop ..
lets hope that this will not be needed..and it is a simple action like I explained in the first lines...
Dec 09, 2011 | Acer Aspire One D150-1587 Netbook
A simple free program that can hide/restore icons on my desktop
Hi hugh hinds....
Try this easy solution to your problem
Please take time to rate me
Hiding Desktop Icons in Windows XPWith a good choice of wallpaper, your computer desktop can add an attractive, even artistic, element to your home or office. Eye-catching desktop wallpaper can be as decorative in its way as a painting or other wall hanging.
If you value the aesthetic potential of your desktop, you might like to enhance it even further by hiding the desktop icons.
Hiding or showing your desktop icons in Windows XP is a simple, two-click procedure.
To hide desktop icons:
  1. Right-click on the desktop and open the "Arrange Icons By" sub-menu.
  2. In the sub-menu, click "Show Desktop Icons" to uncheck it.
The icons should disappear to leave a clean, uncluttered desktop. To show desktop icons again, repeat the above procedure. When the icons are hidden, clicking on "Show Desktop Icons" will enable the option and the icons will reappear.
1...Right-click on the desktop and open the "Arrange Icons By" sub-menu.
2...In the sub-menu, click "Show Desktop Icons" to uncheck it.
Aug 23, 2011 | Computers & Internet
How do I fix the size of my icons and make the internet fit to size
How to resize Vista desktop icons
One of the complaints I hear about the Vista GUI is that "the icons are too big." Well, fixing that is a simple matter. Here's how:
Right click an empty space on the desktop.
Select View.
Click Classic Icons.
Another way is to use the scroll wheel on your mouse or trackball. With the cursor on the desktop, press and hold the CTRL key and scroll the wheel to make icons larger or smaller.
I hope someone having that problem will read this thread.
Cheers!
Jun 24, 2010 | Microsoft Windows Vista Home Basic Edition...
Desktop icon are missing & display is not
Try to uninstall and reinstall the display drivers. For the desktop icons, right click desktop->Arrange icons by->show desktop icons.
May 29, 2010 | Dell Dimension 2400 PC Desktop
Fn and spacebar make icons really big
Hi, right click on the Desktop Screen; select from the "View Icon sizes in the window, "medium, small..." If the solution helped, rating it is appreciated, thanks
Mar 18, 2010 | Toshiba Sattelite A105-S2071 Notebook
Trying to get start button and shortcut icons on the same monitor
go to desktop - right click, select "properties", then "settings", with 2 monitors you should see both here. Make sure you have "extend my Windows onto this monitor" checked.
You should be able to drag the icons over to the same monitor as the start button.
When you drag your mouse across the screen it should move across both monitors.
Hope this helps...if it does, please give me a positive!!
thanks!
Oct 23, 2009 | Dell Computers & Internet
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Desktop icons lost
Sadly, there is no straightforward command you can use to recover them, but well, there are three ways, really, that you can get your icons back, depending on which ones were lost, that you are referring to. for this, I'm assuming you're running a more recent version of Windows.
----- For Windows XP ------
1) for recently deleted icons- check your Recycle bin, they could still be there.
2)for system-installed icons, such as My Computer, and Internet Explorer- you can recover these by going into your Display Properties (Start -> Control Panel -> Display). Select the Desktop tab, and click on Customize Desktop. Make sure the "General" tab is selected, then, under the "Desktop icons" section, tick off the icons you want to restore. click on "Ok" when you're finished, and Presto! those icons are up on your screen.
3)If the above two options don't work, you may have to add them manually ( a pain, I know). To add a shortcut in this fashion, right-click anywhere on the desktop, and select New -> Shortcut. you will have another window appear on your screen, asking you where the file you are making a shortcut to is located, and what you want to call it. follow the steps, and when you're finished, you should have a working icon. (another option would be to reinstall the software that made the icons, but that's also a pain in itself.).
----for windows vista ----
1) check the Recycle Bin (same procedure as Windows Xp, although, if your recycle bin option is deleted, then you have a problem that can be solved by using #2)
2) For system-installed shortcuts- follow This excellent tutorial.
3)Manually installing shortcuts- same as for XP.
Dec 17, 2007 | Computers & Internet
Icons on desktop
Dec 13, 2007 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
