Question about Westinghouse LCM-22w2 Television
White Screen I had it hooked up to my pc and the monitor flickered and went blank. Now when I turn it on it has a blank white screen. Any suggestions?
  • 3 more comments
  • Anonymous Dec 14, 2007
    My monitor did the same thing it was over heating also. When you opened I found that it had a processor chip does it mean that the monitor has been hacked or is there any fix for the problem?
  • Anonymous Dec 31, 2007
    I am also having this problem. The monitor was working when i first hooked it up to my laptop, but within 5-10 minutes, the screen went white. It remains white even if it is not hooked up to anything (except power outlet.)
  • Anonymous Apr 02, 2008
    Have model LCM 22w2. Now I have only a white screen. Nothing seems to help. Have done reboot, unplug, etc. Is there a solution?
  • KennyFace Feb 10, 2009
    First is the Westinghouse LCM -22-w2 a television (with turner?) Or is a 22" flat screen monitor? (I bought mine from a friend going through tuff times, he said he only had it for less than one year) It worked fine for about 5-6 mths. Then it started, whenever I would turn it on (sometimes) it would turn all white and stay that way. I'm not the kind of guy who starts messing with the buttons. (and still haven't... because I don't have manual or install disk. Friend kept saying he would (he had to move and wasn't sure where they were) And I'm a trusting soul, and he was a upfront friend.Who now has moved out of state and hasn't called me in months! (things went from bad to worst for him, his other half died, lost his job, lost his house, last I heard they were looking for his truck, where he was living) Anyway! Has anyone got the drivers and or manual for this? When I hooked it up "vista" had no trouble with it and it works fine. Then slowly as time went on it quit booting up (with picture just went white) so I would shut down computer and retry it again a few seconds later and after 3 - 4 times it would work fine again? btw When I would shut it down I could tell when it was going to start working because it would sometimes show shut down screen for a moment and then shut down, when it didn't show it most times it starts booting and quickly gos to white screen???? This got to be such a pain so I hooked up my old 17" up and just let it sit for a month or two!
    Does anyone have any suggestions? (do you think if I install the drivers it might fix this?) Or any ideas how much it might cost to have it repaired? Or put it the dumpster?
  • findgaryh Feb 12, 2009
    Yup, pretty much the same thing, first mine wouldn't turn off - instead it would go to that white w/ light grey smear display, then one day total death, and as mentioned garbled text display of the on-screen menu.
    I'm still negotiating with Westinghouse Digital over a service manual, but so far they're pretty adamant about that "only to authorized service center" ****. If I do manage to fix it, I'll re-post. I'm hoping it's power supply related, as that's easiest to fix w/o schematics, but based on experience, only figure that as about 30-40% likely.
  • 13 Answers
I fixed it!
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
Posted on Apr 09, 2009
This is not a solution but I've had the Westinghouse LCM-22w2 for probably a little over a year. A few months ago it display all white when I turned it on. Along with this problem the on screen display of the channel select and the UI config menus were corrupted. (although you can still change channels and use the menu functions)
The white out problem was a nuisance for a couple months and I learned a few things about it. First of all, it seemed to only happen if I turned the monitor off and let it cool down. Changing the channel modes doesn't help as much as just turning it off and on until you get the picture back but it felt like maybe it was trying to warm up or something
a couple weeks ago, the white screen problem turned into: everytime a resolution change happened, the screen would flicker and blink corrupt pixels. The only way to get it to cooperate was to turn it off and back on again. It's not really such a pain, when windows boot it changes resolutions like 3 or 4 times but in the end, I'm thinking 'ok, not a show stopper'
Today my Westinghouse was in the stages of restarting windows when it went first I thought it was just a resolution recycle like I was mentioning above. But no, now it has no picture...on any the little orange LED on the front to indicate power does not light up.....there's no high frequency noise to indicate it has the will to live....I can unplug it and plug it in and it squeals for about 3 seconds and then nothing....a couple of times the squeal has remained on (still no LED indicator on the front) but nothing happened just seems like it might for a second but no.....
So I guess my point is....if you see the white screen treat it like a strange and unsettling death omen.....the resolution handicap was next, and then was just it had never had a soul in the first place....Goodbye my friend....goodbye 22w2....we barely even had time to know you...but I guess one gets what one pays for and westinghouse's purpose in life is to serve as a warning of that lesson :)
Posted on Jul 30, 2008
Monitor has white screen
After understanding your issue with the monitor I hate to say this but unfortunately you have to consider replacing your monitor.
Thanks for using Fixya
Feb 21, 2013 | HP w1907 LCD Monitor
Computer monitor is white
What do you mean, white screen?
It just went blank after a few minutes of use?
Anyway, you've already eliminated the monitor as the surce of this problem, so it can now be either the cable from your monitor to your PC or your graphics card. I suggest you try another monitor, and if that doesn't work, find someone to temporarily insert another graphics card into the system.
One of these should fix the problem,
Jun 16, 2009 | HP Pavilion F1703 17" LCD Monitor
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
May 25, 2008 | Computers & Internet
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Westinghouse LCM-22w2 Television Logo
1,322 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
