Pitney Bowes 9920 Plain Paper Fax Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change Date How do I change the date on our 9920
Nike Merritt
Level 2:
  • Expert 149 Answers
  • Posted on Oct 05, 2009
Nike Merritt
Expert
Level 2:
Answers
149
Questions
0
Helped
65969
Points
272
Press function repepetedly until system setup? press yes, Set time and date? press yes. enter a two digit for month, i.e 01 for january, 12 for december, then two digit day, two digit year, press yes, stop to exit.
If you need a code, use 9920
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
2helpful
How can I change the date without turning 24 hours ?
mcdevito75 here, Most day / Date or just date watches with a stem (winder) even if they are quartz have a 2 position stem. Smply slip a fingernail under the crown and lift to it"s first position, this should allow you to change the date with haveing to go the 24 hours but remember the date cahnges at 12--1 Midnite, Best bet, change the date to the date before the date you want then go the 24 hours this way the date will change at midnite and not 12 noon.
How do i change the time and date on the 9930?
Go to www.oceusa.com, click drivers and support, find 9920 or 9930 in the dropdown list, look for manual link and download pdf file. any password you need will be your model no. 9930
5helpful
How to change th date in Tally 7.2 educational single user?
in tally 7.2 version there is no changing date.please advice me in detail and clearly
Cannot change date
Go to "Settings", then Option 4 ("Time and date"). Make sure the 'Time zone updating" option is set to either "Prompt first" or "Manual only" (NOT "Automatic"). Then try changing the date.
3answers
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
1helpful
Date/time
Hit function key, then the number 8, then Yes. This will get you into all the functions and date and time is either the first or the second thing.
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Wrong Date - no confirmation page - Access code
I have not worked on any Pitney Bowes before, but I am sure you can find a manual on their website. Sounds like you might need a firmware update. Also try justmanuals.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Pitney Bowes Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
