HELP i need the solution for this Java program and the hole code and the program as soon as possible :implement a simple GA with fitness-proportionate selection, roulettewheel sampling, population size 100, single_point crossover rate pc = 0.7, and bitwise mutation rate pm=0.001. tray it on the following fitness function: f(x) = number of ones in x, where x is a chromosome of length 20. perform 20 runs, and measure the average generation at which the string of all ones is discovered. perform the same experiment with crossover turned off (i.e.,pc=0). do similar experiments, varying the mutation and crossover rates, to see how the variation affect the average time required for the GA to find the optimal string . if it turns out that mutation with crossover is better then mutation alone, why is that the case?
I open a link with word document and I get code execution has been interrupted, and it asks me if I...
(More)
I open a link with word document and I get code execution has been interrupted, and it asks me if I want to debug, stop, clear, and click next on the pop up display.
I need a to design an application that contain two protein sequences. The second and first sequence...
(More)
I need a to design an application that contain two protein sequences. The second and first sequence is to be compared and find out if the second sequence is present in the first sequence.
i wish to preview a text base report before printing . i used rich text file but the out put is...
(More)
I WISH TO PREVIEW A TEXT BASE REPORT BEFORE PRINTING . I USED RICH TEXT FILE BUT THE OUT PUT IS DISTURBED.. I DO NOT WANT TO USE DATA DESIGNER OR CRYSTAL REPORTS. THE OUTPUT SHOULD BE PREVIEWED ALONG WITH PAGE SETUP & PRINTER CONTROLS. IS IT POSSIBLE TO DO SO ?
