Ulead CD & DVD PictureShow 3 Deluxe  for PC
Problem for Ulead CD & DVD PictureShow 3 Deluxe (CDDVDPIC3D) for PC
Download problem
By raju boro on Dec 13, 2007
Dear sir,
please help me how to download the adobe photoshop.I have tried many times but i can't it >Please suggest me as soon as possible so that i can download the adobe photoshop.........
Same Problem
Dec 07, 2008
-   foxconn662mxsis-   Guest
Feb 04, 2008
-   I can't find my down load anywhere...for logo design.-   Guest
Best Solution
posted on Dec 14, 2007
Helpful)
Beni S-P
Rank: Wiz  Computers & Networking  Expert
Rating: 85%, 2398 votes
here you go:
Adobe Photoshop CS3 INFO:
Adobe Photoshop CS3 software, the professional image-editing standard and leader of the Photoshop digital imaging line
Adobe Photoshop software, the professional image-editing standard and leader of the Photoshop digital imaging line, delivers more of what you crave.
Groundbreaking creative tools help you achieve extraordinary results. Unprecedented adaptability will let you custom-fit Photoshop exactly to the way you work. And with more efficient editing, processing, and file handling, there’s no slowing you down.
Create with unmatched power
Timesaving file handling with Adobe Bridge (formerly the File Browser)
Multitasking.Take advantage of compact floating mode in Adobe Bridge to process images while simultaneously working in Photoshop.
Viewing options
Easily browse your Adobe Creative Suite and other graphics files in Adobe Bridge; present your images with features like Slideshow and Filmstrip mode; scale thumbnails to any size using a slider; and view and edit metadata.
Automated batch processing
Automatically process batches of images in Adobe Bridge to rename, convert format, adjust exposure, create a web gallery or Adobe PDF Presentation, and more.
Rating and labeling
Quickly rate and label photos in Adobe Bridge so you can instantly bring up your best shots.
Sophisticated search
Easily find any image using sophisticated search capabilities in Adobe Bridge that let you specify a variety of parameters. Save searches as Collections that you can recall anytime.
Professional color and tone control
Match Color command
Achieve a consistent look between package shots, fashion photos, and more by instantly matching the color scheme of one image to another.
Color Replacement tool
Easily change the color of any image area while retaining the original texture and shading.
32-bit High Dynamic Range (HDR) support
Create and edit 32-bit images, and combine multiple exposures into a single, 32-bit image with expanded range?from the deepest shadows to the brightest highlights.
Histogram palette
Monitor color changes to your image in the Histogram palette, which dynamically updates as you make adjustments.
Shadow/Highlight correction
Quickly improve the contrast of over- or underexposed areas of an image, including CMYK images, while preserving the overall balance of the photo.
Color management guidance
Get precise, consistent color from display to output with helpful color management guidance.
Intelligent image editing
Revolutionary Vanishing Point
Achieve amazing results in a fraction of the time with the groundbreaking Vanishing Point, which lets you clone, paint, and paste elements that automatically match the perspective of the surrounding image area.
Image Warp
Easily create packaging mock-ups or other dimensional effects by wrapping an image around any shape or stretching, curling, and bending an image using Image Warp.
Spot Healing Brush
Effortlessly retouch photos?including 16-bit images?in a single click with the advanced power of the new Photoshop Spot Healing Brush.
Healing Brush
Perform expert retouching to remove dust, scratches, blemishes, wrinkles, and other flaws with minimal effort using the Healing Brush
Essential photography tools
One-click red-eye correction
Instantly neutralize red eyes with the one-click red-eye correction tool, which supports 16-bit images and lets you set pupil size and darkening level.
Optical lens correction
Easily correct common lens distortions, such as barrel and pincushion, and fix chromatic aberrations and vignetting.
Smart Sharpen
Easily counteract common image blurring with fine correction control based on the specific blur types: motion, lens, and Gaussian.
Advanced
noise reduction
Polish digital photos with advanced noise correction in high-ISO shooting plus JPEG artifact reduction.
Camera raw workflow enhancements
Process an entire photo shoot in a fraction of the time by simultaneously adjusting color, curves, cropping, and more?and continue working in Photoshop! With support for a comprehensive range of digital cameras, Photoshop lets you automatically adjust settings, convert to Digital Negative (DNG) format, and apply nondestructive edits to batches of images.
Comprehensive 16-bit support
Perform precise editing and retouching with support for 16-bit images in core features, including layers, brushes, text, shapes, and more.
Crop and Straighten command
Scan multiple images at once and let Photoshop automatically straighten and save each image as an individual file.
Design freedom
Flexible layers
Composite images, text, and effects on hundreds of layers that you can organize with up to five levels of nesting and save in different combinations as Layer Comps.
Painting and drawing tools
Create or modify images with a wide assortment of professional, fully customizable paint settings, artistic brushes, and drawing tools.
Special effects filters
Achieve amazing results with more than 95 special effects filters. Easily preview and apply more than one filter at a time from the Filter Gallery.
Advanced type control
Add vector-based text that you can edit at any time, format, warp, place on a path, convert to outlines, and use for masks or other special effects.
Advanced web capabilities
Create sophisticated web page elements with rollovers, transparency, image slicing, and more.
Web animations
Quickly create dynamic GIF animations?using one or more images?directly within Photoshop by taking advantage of the new Animations palette and layer palette animation options
Customize with unprecedented adaptability
Adaptable workspace
Custom menus and keyboard shortcuts
Set up and save custom menus and keyboard shortcuts for quick access to the features you need.
Custom, task-based workspaces
Reduce onscreen clutter by choosing from task-based workspaces, or create your own with just the tools you need.
Adobe Help Center
Quickly get answers from the new, floating Adobe Help Center window with improved search features and convenient, task-based topics.
History Log
Automatically track all editing steps within your Photoshop files. Export steps to a text file or save them as part of image metadata for easier documentation of your work, file audits, and more.
Flexible measurement systems
Enter precise numeric values in inches, pixels, and other measurement systems. Even enter different measurements on-the-fly without changing global settings
Automated image processing
Links: http://rapidshare.com/files/74640212/photo_cs3.part01.rar
http://rapidshare.com/files/74669474/photo_cs3.part02.rar
http://rapidshare.com/files/75514140/photo_cs3.part03.rar
http://rapidshare.com/files/75542536/photo_cs3.part04.rar
http://rapidshare.com/files/75575871/photo_cs3.part05.rar
http://rapidshare.com/files/75712872/photo_cs3.part06.rar
http://rapidshare.com/files/75732517/photo_cs3.part07.rar
http://rapidshare.com/files/75751914/photo_cs3.part08.rar
http://rapidshare.com/files/75762829/photo_cs3.part09.rar Pass: freshdl.com Or http://rapidshare.com/files/66187460/AP.CS3.sxforum.org.part1.rar
http://rapidshare.com/files/66199878/AP.CS3.sxforum.org.part2.rar
http://rapidshare.com/files/66212869/AP.CS3.sxforum.org.part3.rar
http://rapidshare.com/files/66254078/AP.CS3.sxforum.org.part4.rar
http://rapidshare.com/files/66276200/AP.CS3.sxforum.org.part5.rar Pass: sxforum.org
Was this helpful?
Yes
No
Solution #2
posted on Feb 16, 2008
Somewhat Helpful)
honey2509
Rank: Wiz
Rating: 84%, 170 votes
Adobe Photoshop CS3 With LightRoom
The professional photographers' toolbox.
Adobe has begun shipping Photoshop Lightroom 1.0, its professional level digital photography application and also that it has released updated Camera Raw 3.7 software with additional support for digital cameras. Available for both Windows and Mac platforms, Adobe Photoshop Lightroom allows photographers to import, manage and present large volumes of digital photographs. Photoshop Lightroom includes several new innovative features that streamline digital photography workflows.
Adobe said that the tools and features in Photoshop Lightroom help photographers tailor their digital photography workflows. The Library and Develop modules have the organizing and editing features for image management and non-destructive editing, and Photoshop Lightroom makes it easy to send images to and from Photoshop for pixel editing. Once editing is complete, users can showcase their images in Photoshop Lightroom with the Slideshow, Print and Web modules.
Download
http://rapidshare.com/files/9506953/PShop_CS3_AIO.part1.rar
http://rapidshare.com/files/9505450/PShop_CS3_AIO.part2.rar
http://rapidshare.com/files/9505277/PShop_CS3_AIO.part3.rar
http://rapidshare.com/files/9503081/PShop_CS3_AIO.part4.rar
http://rapidshare.com/files/9502702/PShop_CS3_AIO.part5.rar
http://rapidshare.com/files/9500924/PShop_CS3_AIO.part6.rar
Pass: www.heartodark.com
Was this helpful?
Yes
No
Solution #3
posted on Jun 11, 2008
Not Rated)
adamya
Rating: 80%, 77 votes
download at torrentz.com
Was this helpful?
Yes
No
Popular Solutions for Ulead CD & DVD PictureShow 3
Questions and Unsolved Problems for Ulead CD & DVD PictureShow 3
Do you recommend Ulead CD & DVD PictureShow 3 Deluxe (CDDVDPIC3D) for PC?
Answer
Answer
I choose all the photos I want to include. I click create CD/dvd slideshow, but the next page has no... (More)
Answer
I changed computer. I installed two hard disks on my new computer. The second hard disk is my old... (More)
Answer
get all the way to create cd section and a box comes up for roxio products. I cannot get rid of it... (More)
Answer
Hi there i am experiencing a problem ... when downloading the project to a Dvdrw it comes up with... (More)
Describe your Graphics Publishing and... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Graphics... Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
