Question about Gateway SL9550-30165318 Notebook
No display lights
My gateway laptop just lost its lights on the display works well but no screen lights
    Novelist:
  • 77 Answers
There are two possibilities, neither is really for a novice.
TURN OFF LAPTOP, REMOVE AC PSU AND BATTERY
Open the laptop lid and check the thin ribbon cable (looks like dirty yellow or orange scotch tape with several small thin metal lines parallel to each other). This comes down from LCD/screen, to the lower laptop case. It will have a connector that has a clip/release compressing the ribbon in the jack. Release it, and GENTLY pull the end out. Old laptops get oxidation here that causes your symptoms. Use a stiff piece of CLEAN denim material ("jeans" to "buff" or "polish" the bare metal at the end of the cable. Then insert back into the jack and press the clip down evenly.
Reassemble laptop. If symptoms remain, then it is your fluorescent tube. Laptops have VERY thin fluorescent lights, about 2-3mm in diameter. You need to open the LCD/SCREEN case, and take NOTES how everything is taped inside as you disassemble. On the sides or top will be (usually) two, sometimes only one illumination tube sealed in a channel. If it has black or grey color at either or both ends, it is burned out. You will need to remove it and replace it. If the tube is NOT burned out, then it is either the connections (check all, in the area/connecting to tube). Last, if nothing was loose then your inverter is bad. If it is soldered to the main board, your laptop is "toast". It is over, unless you can find a GUARANTEED used or new replacement for a price you feel is good. However, if the inverter is inside the LCD/Screen/LID, this can often be a plug-in unit that is replaceable, if you can find the parts (again, for a price you feel is worth it).
Posted on Dec 14, 2007
I dropped my gateway laptop and now when I turn it on all the lights and fan come on but screen is black,
With the laptop powered on, press f8 repeatedly or until screen resumes normal display.
Apr 14, 2014 | Gateway M Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
My gateway computer is blank
probebly the screen issue... you need to check your laptop with external monitor and make sure that it shows the display
Nov 19, 2011 | Computers & Internet
Hi my gateway just lost the light on the
Turn it off. Wait 1 hr. Restart. It could be that the video card is overheated.
Mar 23, 2010 | Gateway MT3422 RTL Notebook
Got a gateway loose complitely the light of screen,but it starts you can hear it, the window but no light
check ribon cable by taking laptop apart and makign sure its conected to board correctly, but more than likely new bulb or replacement screen , search ebay they have a tone of secound hand screens for decent prices, search gateway 450rog lcd displays, hope this helps in some way
Dec 04, 2009 | Gateway 450ROG Notebook
I have a 7322gz gateway laptop.back lts work but nothing displaye
On most notebooks, switching between the internal display and the external display is done by pressing Fn+F4.
Aug 02, 2009 | Gateway 7322GZ Notebook
Screen on my laptop will not work. Black screen.
Test if it works on external monitor. If it does, then turn the computer on, remove the battery, then reinsert the battery. That little trick has worked several times for me and my customers. If the external monitor does NOT work, then you probably have a bad video chip in the computer's motherboard.... by the time you fix it, you could almost by a new machine.
May 25, 2009 | Gateway M305CRV Notebook
LCD went dark
hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
Jan 14, 2009 | Gateway MT6707 Notebook PC
Gateway laptop wont display my desktop -screen is black
Does backlight stay on, or does it look like the screen is turned off? If it looks like it is turned off, can you look extremely closely and see your desktop if held in good light?
Jan 04, 2009 | Gateway 450ROG Notebook
Gateway SL9550-30165318 Notebook Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
