Your later generation Apple iPod can be locked to protect your personal data from anyone else's eyes. There are a variety of ways to unlock it depending on your access to the combination, the primary computer linked with the iPod, or neither. Difficulty: Easy Instructions
Unlock with the Combination
Remember the 4-digit combination you used to set the screen lock.
Enter the exact combination. If the combination is correct, the iPod unlocks and displays the screen you were on before you locked it.
The numbers on the screen flash red if you enter the code incorrectly. Unlock with the Primary Computer
Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
Open iTunes and sync the iPod as normal.
Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it. Unlock by Restoring
Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Ipod Lock
You can unlock iPod in one of two ways:
1...Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
2...Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Important: Apple representatives cannot unlock an iPod if you forget your combination.
If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Good Luck, I hope this helps
Please rate me, Thanks
Ipod Lock
Good Luck,
I hope this helps
Ipod Lock
Good Luck,
I hope this helps
Ipod Lock
You can unlock iPod in one of two ways: 1...Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen. 2...Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
Important: Apple representatives cannot unlock an iPod if you forget your combination. If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Ipod Lock
Ipod Lock
Ipod Lock
Unlocking iPod
iPod.
