Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
Please hlep i am not able to adjust the resolution for this screen after i formattted my computer.. what do i do in order to solve this problem ? Do i need to down load its driver and i from where can i download it online ? Thank you, Simon
  • 138 Answers
Try your monitor with another computer and check if you can adjust the resolution or not.
Posted on Feb 07, 2008
Hi, Fixya I have a by D:sign LCD TV model nr STY0340 How do I remove the auto adjust function when on Pc mode as the screen pulls to the right when I connect my Laptop Please assist..
You may need to use some of the menu buttons on the TV\monitor itself in order to manually adjust this and prevent the auto adjust resolution from taking place. Additionally you may need to specify whether it's 16:9 or 4:3 resolution from within the picture settings.
Oct 24, 2017 | The Computers & Internet
Images on my screen have been overly enlarged to set it back to original
Close any open programs and close open documents.
  • 2 Right-click in a space on the desktop where there isn't an icon.
  • 3 Click on "Properties". The "Display Properties" window will open.
  • 4 Select "Settings".
  • 5 Locate the "Screen Resolution" box in the lower-left part of the screen.
  • 6 Click and hold your left-mouse button above the downward-pointing arrow in the "Screen Resolution" box. Move your mouse up and down the bar to adjust the screen resolution.
  • 7 Release the left-mouse button when you arrive at a satisfactory screen resolution.
  • 8 Click "OK" to set your screen resolution.
  • 9 Restart your computer to apply the settings.
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
    Thanks, Joe
    Jan 08, 2011 | HP Compaq 6510b PC Notebook
    Screen magnified.. right clicking nothing happening
    Try using the start menu to open the control panel and select Adjust Screen Resolution. If adjust the resolution doesn't solve the problem or you can't access the control panel in any way you may have a more serious software problem at hand and should see a computer repair shop.
    Sep 27, 2010 | HP Pavilion G61336NR Notebook
    Having the same problem as others, my 912n monitor is a black
    The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
    Jan 17, 2010 | Samsung SyncMaster 912N 19" Flat Panel LCD...
    How can I solve the adjusting of the monitor if I haven't the resolution size. When i start windows the monitor give me a message,it tell me that the resolution screen is donw,and the program dosen't have...
    When you start windows Pres ATO button for automatic adjustment.
    If issue has been not resolved than reinstalled VGA driver in your system.
    After reinstallation of Display driver the monitor automatic adjust Resolution.
    Abhay Singh
    Nov 24, 2009 | Gateway FPD1975W 19" LCD Monitor
    Out of frequency set resolution or see monitor
    If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
    If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
    Oct 04, 2009 | Compaq 7500 17" CRT Monitor
    Can't see items on bottom of screen
    Use the adjustments on your monitor to scroll the screen display up a little bit. (Press enter to use the OSD, adjust the geometry or vertical position.)
    If you're talking about the taskbar itself, on the other hand, and you are using xp, see here.
    Then follow these instructions to scan your system for malware.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jun 06, 2009 | Computers & Internet
    Resolution problem with xp
    Here is a link to the instructions for resetting the resolution for your monitor: Resolution/Refresh
    If you need other information about your monitor please look here
    Mar 31, 2009 | SAMTRON 55V 15" CRT Monitor
    Wide screen 21 inch KDS monitor
    It shouldnt be a problem with the monitor, but with the computer. Unless adjusting the resolution solves the problem, im not sure what to do. Sorry, hopefully that helps.
    Dec 31, 2008 | Computers & Internet
    I cant see but half tge game on the screen. the other half is beyond the right side of the monitor. please help
    In order to solve this problem you will need to adjust the games resolution in order to match your screen or vice versa. In order to do so in the game it should be under your video options menu. In order to adjust windows to match the game simply right click anywhere on the desktop click on personalize or properties, then click on appearance. From there you can adjust your screen size to match. simply slide the bar left or right depending on whether you want the screen to be smaller or larger and then click apply.
    Jul 10, 2008 | Take 2 Interactive Jetfighter 4 for...
    Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
    66 people viewed this question
    Alun Cox
