Question about LG Flatron L1718S LCD Monitor
Monitor Stand Can you please let me know how to remove the stand from the monitor prior to repacking.
  • jenrzzz Feb 24, 2008
    Can't remove the base- I need to put it back in the box to take to a customer's site.
  • Anonymous Mar 30, 2008
    Yep,
    I've got the same problem - the bottom bit unclips, but what about the column?
You have to lay the monitor face down, then pull the column hard at an angle until one side clicks out, then pull to get the whole thing off. It's detailed in the manual on the LG website.
Posted on Jan 01, 2009
How can i remove LG Flatron L1718 back panel
Posted on Feb 07, 2009
Can we remove stand from monitor HP 2010i
Dear yes you can remove stand of HP monitor with the unlock behind the monitor near stand neck.
Thanks
Firoz Ali
Apr 28, 2014 | Computers & Internet
Remove stand from lenovo li2321s monitor
in between the stand rails is a removable piece of plastic with a sticker that contains the "nutritional information" about the monitor. If you remove/pry it off you will fine 4 screws that remove the monitor stand completely.
Jan 30, 2013 | Lenovo Computers & Internet
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
I cant remove the stand of my LG 194WT monitor
Here is the manual for your monitor, it will give you the instructions on how to remove the stand.
http://www.retrevo.com/support/LG-L194WT-Monitors-manual/id/440bh350/t/2/
Feb 28, 2011 | Computers & Internet
I'm attempting to repack my AL2216W LCD Monitor into the original box. When I slide the two foam protectors on the ends, it won't fit into the box. The stand is in the way no matter how I position the foam...
Of course there is a trick to this. Remove the stand by pushing gently on the clip at the bottom. I usually turn it upside down to do this. Then lay the stand on top side of the foam.
Please rate this answer as the only thing I get for answers is a rating.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
How do you remove the stand from a BenQ 767?
remove screws either side where stand go into back of monitor.
then slide stand toward bottom of monitor and it should slide out
Jan 14, 2010 | BenQ FP767 17" LCD Monitor
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Acer AL1916W 19" for wallmounting
remove the both screws at the backside and stand will go unmounted.. now you need two stripes to hang your monitor on the wall.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
LG Flatron L1718S LCD Monitor Logo
1,993 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
