Question about Panasonic Lumix DMC-FX7 Digital Camera
Power up problem
When I turn the camera on, it tells me that I have to "turn the power off then on again." It started a month or so after I got it and I have barely used it. No damage to it at all.
  • fenixdt2287 Dec 17, 2007
    same as the person before me, every time I try to turn the camera on, it will zoom in and out (by itself) a few times, then ask me to turn it off and then on again. The only time it will remain powered up is if i put it in playback (picture viewing) mode. I've popped out the battery and memory card and put them back in, to no avail. unfortunately i bought the camera from a friend and have no manual for it.
  • Anonymous Dec 29, 2007
    When I turn on my camera the shutters wont open and it tells me to turn off the camera and turn it on again, the zoom wont move either.
    Scholar:
  • 48 Answers
Try resetting the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Panasonic's website and look for firmware updates. Download and install them.
But it also may be underpowered batteries. So make sure you're using the recommended battery types. I recommend using high energy batteries designed for digital photography. Varta is a good brand. They are usually sold in camera shops, are long lasting (because they are sold in small quantities) put out alot of energy.
And, even though you think you've put in fresh batteries, underpowered batteries are just as bad. At the very least, make sure you are using Alkalines. Even better, batteries with a higher mAh - like around 2500mAh would satisfy the higher power requirements of your camera.
Posted on Dec 18, 2007
Both cameras has stopped working,help
Maybe you can try pressing and holding the power button until it turns off then keep holding it until it turns back on and see if that works
Jan 01, 2014 | Nextbook Next 7 PRO Tablet
When i turn it on tried to access then tell me to turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Setup 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Jun 19, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
Have a sony cyber- shot and out know while usign it the zoom started moving in and out on its own. now the camera turns on but just zooms in and out and then tells you to turn it off and on again
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
May 11, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
When the power is turned on, the lens stays in the camera, it starts beeping and it tells you to turn the power off and on again
1) Remove SD Card.
2) Remove Battery.
3) Hold power button for 10 seconds.
4) Install Battery.
5) Attempt to power on.
6) If works, reinstall SD Card and you're ready to go!
Thanks and please rate if this helps you!
Mar 29, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
Camera what close, keeps telling me to turn power off and on again
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Jan 13, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
My dsc-w350 tells me to turn the power off and on again
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Dec 05, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
My fe-280 model has color problems.
Has this camera ever been left in a hot car?
Apr 17, 2010 | Olympus FE-280 Digital Camera
Camera tells me to turn power off and on but dosent work
Turn on the camera.
Jan 17, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
93 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
