My screen shuts down
I turn my lap top on the loading page comes up and then the screen just shuts down the hard drives still going so its not powewr ?/ thanks
  • 4 more comments
  • datto Dec 13, 2007
    the screen lights up still and acer symbol comes up then shuts down some one help lol
    an oh yea i can do nothing the screen is jus blank but lit in the back round
  • Anonymous Jan 28, 2008
    i tried to reinstall windows and now it tries to boot up and stops at a blank screen
  • Anonymous Feb 10, 2008
    I have the same problem the 5100 Aspire it boots and then I get the blank screen , LETS GET SOME SOLUTIONS HERE
  • glog7 Mar 19, 2008
    turn computer on, processor is working but there is a blank screen. Computer is working because projector show screen picture. Unhooked and restarted, still same result.
  • rajahudda Apr 25, 2008
    my notebook jus goes blank mostly wen i put it for charge...there is this blank screen that comes up but the power light is still on..if i restart with the charger plugged in then i get a white screen..its weird but really need sum help...plsss
My laptop loads in the background of the screen which is blank it was sometimes coming on at times when i plug into the power cord and reboot the system the screen would come on... Now its not coming on at all. Help thanks I have not dropped it or over used it at all.. It is an acer 5100-3583 series model BL51... any solutions would be helpful since its still practically new..oh yeah i also tried to plug a monitor in the external port to still be able to use it and the monitor would not come on either..... I am at a lost not only of money mind and knowledge on this subject...
Posted on Nov 16, 2008
    Sergeant:
    Champion:
  • 244 Answers
Try to remove the hard drive, dvd and power on again.
some devices could cause that problem.
Posted on Jan 19, 2008
I am having the same problem, and I'm still looking for a permanent solution, but...... as a temporary fix, I had to boot in safe mode then disable the nVidia display device from the device manager. I can now use the computer as normal, but I have bad resolution and can't use the svideo out. I'm hoping there isn't a hardware problem.
Posted on Jun 13, 2009
We have a Toshiba Satellite lap top. It was working about an hour ago, when we down loaded a BIOS upgrade from 1.4 to 1.5. After the down load and reboot the lap top now has a black screen with no wording....
BIOS updates sometimes cause the motherboard to revert to its default configuration. I recommend that you go into the BIOS setup and examine the Boot Devices and Boot Order to make sure that your hard drive is selected as the first boot device.
Oct 07, 2010 | Computers & Internet
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
Satellite M45-S351 locks up won't shut down. First thing, may lap top would not shut down so we had to use the power button, then after some time 2-3 the unit decided not to boot up. we copyed the hard...
I think it is a prob with the mother board.........no need t change RAM or hard drive........they dont cause this type of prob. Ur mother board is not accepting the shutdown command.
Try the following command in command prompt:
shutdown /s /f
May 23, 2010 | Toshiba Satellite M45-S351 Notebook
IR Problem
needs new hard drive, new reinstalation of vista or xp. the problem is it passes Bios but it doesnt load the operating system, it passed the video graphic permission.
can you replace hard drive yourself?
Jul 30, 2009 | Dell Latitude D600 Notebook
My lap top says that my hard drive is going to fail
You should back up your files regularly and be prepared to purchase a new hard drive and install Windows on the new hard drive etc. when the hard drive eventually fails.
Apr 16, 2009 | Gateway Computers & Internet
New 100gb MK1031GAS hdd not recognized in bios
you fit a new hard drove and it is a blank page
of course the bios will not recognize it
you have to get into bios and change the boot sequence from hard drive to cd as first boot preference
shut down the lap top, after loading the cd in the cd unit then restart
the bios will boot from the cd and install the operating system onto the hard drive
When done ypu can get back into bios and reset it to first boot from hard drive
Feb 03, 2018 | Toshiba (MK1031GAS) 100 GB Hard Drive
If your os is Vista try this.Use your vista restore disk.Put it in your cd-dvd player and run it .When it ask you what do you want it to do select start up repair.Repair will run,then your system will reboot.If this doesn't work i would check your lcd inverter or lcd panel.
Dec 09, 2008 | Acer Aspire 3690-2196 Notebook
Lap top wont boot up past the windows screen
This generally indicates that a sector in the hard drive has failed, and the hard drive will need to be replaced. With a bad sector the drive reads to the point of the bad sector and past the bad sector, but can't put the info together, so it tries to boot, but can't. Unfortunately, your only option is replacing the hard drive.
Aug 01, 2008 | HP Computers & Internet
Wireless
System viruses are suspected- try formating the Hard drive
Dec 16, 2007 | Acer Aspire 5101WLMi Notebook
Computers & Internet Logo
521 people viewed this question
Alun Cox
David Payne
David Payne
