Question about SanDisk Sansa m250 MP3 Player
Interupted download after reformat... frozen.
Hoping there might be a solution. Stuck on initializing and wont be recognized by WMP10.
I had a similar problem, although mine kept saying my mp3 wouldn't take subscription music. I just don't use wmp. I have set up so my music downloads to a music folder and then just copy files to my e drive.
Posted on Feb 22, 2008
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
Won't switch input settings
this is a manufacturer defect I would suggest contacting them and hopefully getting a replacement for it or at bare minimum they should give you a means to reset the tv to its manufacturer default hopefully enabling the features that came with it
hope this helps
Apr 27, 2010 | Initial HDTV-320 32 in. LCD TV
The printer isn't recognizing that it has paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 22, 2009 | HP DeskJet 970cxi InkJet Printer
Unable to initialized
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
Jun 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
Stuck on finalizing update and computer wont recognize.
yet i don´t know much about your mp3 ..
is there any reset "button" if so try that
May 25, 2009 | SanDisk Sansa m250 MP3 Player
Firmware problem
See the solution for PC not recognizing your player. You should downgrade to WMP10 by uninstalling WMP11 and WMP11 runtime. Uninstall portable device drivers from System menu and restart the computer. Replug the USB and the player should now be recognized.
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
Creative zen microphoto v0.0.65
my creative zen is being dumb no matter what i push the recovery mode is still gonna be there what do i do
Nov 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Stuck on initializing screen
Call Sandisk support. This is a known problem with this model that was sold in December 2006. Apparently later models fixed the issue. They will get your info and do an RMA, and they even provide the UPS shipping label.
They were great to deal with. I hope you have the same success.
Oct 25, 2007 | SanDisk Sansa m240 MP3 Player
Firmware Problem
I had this problem as well and found help. I tried the suggestions below and the problem was fixed! What you can try is this: Open up Control Panel Click on Performance and Maintenance Click on System Click on Hardware tab Click on Device Manager button If you see a Yellow Exclamation mark beside something that looks like the DJ then double click on that. If you see something that says to Update the driver then do so. If it asks to checked Windows Update, choose this option!! If this fails then delete it from your computer by pressing the Del key then clicking OK. Restart the computer, connect your DJ and see if it works properly. If not, open up Device Manager again. This time remove ALL your USB ports, everything under Universal Serial Bus controllers. Restart your computer, let it reinstall your USB devices, connect your DJ with its done, hope it works... If not, open up Add/Remove Programs Click on Show Updates box in the top middle if your running Service Pack 2 Scroll all the way down until you see Windows Media Player 10. If more than one WMP 10 item is showing then remove those first. After your PC restarts remove WMP10. If removed successfully then your computer will now have WMP9 installed. Open up WMP9, click on Help, click on Check for Player Upgrade. WMP10 should be displayed. Let it update... After your computer restarts, install the Windows Media Format 9.5 Runtime from this sticky Restart your computer, connect your DJ and hope it works....... Or you can just take it to another computer running Windows XP and WMP10 and if it recognizes correctly then put back a v1 firmware, I recommend 1.02.01. Download it from this FAQ Hope this helps you as much as it helped me.
Jan 22, 2007 | Dell Pocket DJ MP3 Player
SanDisk Sansa m250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
