Question about PC Laptops
Keybords problem Pls. help me to solve my problem. I am using acer aspire 5680 and having a problem with my keyboards, when I type i need to hold for 3 seconds to response i dont know why there is a delay.
  • 46 Answers
SOURCE: acer aspire 5680
Try to go in the BIOS Configuration and load the default values.
Posted on Dec 13, 2007
0 characters
1 Points
How to brighten screen of laptop acer aspire 5610z without keybord ?
May be there is any facility in control panel depends upon the video driver
Jul 20, 2012 | Acer Aspire One PC Notebook
How do I remove keyboard on acer aspire 5510 to find CMOS battery for removal to clear BIOS password
Underneath your laptop there should be to screws with a small logo of a keybord remove the screws then gently lift the keybord with caution as there maybe some retaining clips holding it in place, then remove the cable by sliding the retaining clip out,
Dec 02, 2009 | Acer PC Laptops
No use oflefthand keyboard
whoever gave you that solution wouldn;t work. problem such as this are due to hardware and not bios. the only solution is replacement
Nov 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5570 kyebord
On the bottom there should be 4-6 small screws that have little keyboard labels on them. Remove the screws then pull the keyboard off the laptop, but be very careful and don't force it. If it does not come easy you may have missed something. There is a small ribon connector that attaches the keyboard to the motherboard. Unlock the slide lock, pull and reseat the ribbon. Put the keyboard back on and test. If it is still having a problem the keyboard or the connector may be bad. You might also go into control panel, hardware, device manager, and reassociate the driver for the keyboard.
Mar 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5680
How many year do you using your laptop?
If more than 2-3 you need to change battery inside laptop. It is little battery (3V)
Sep 13, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 5680
Dec 13, 2007 | PC Laptops
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
PC Laptops Logo
51 people viewed this question
Top PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Laptop Expert? Answer questions, earn points and help others
