Question about Intel Motherboard
Hard drive install
Ive installed a new harddrive on my pc bt since i have there is no screen display from start........ive checked the wires ive checked the display card and it is plugged in....what could the problem be?
  • Anonymous Dec 13, 2007
    HDD can't dislay windows?
  • RAVENCROUS Dec 13, 2007
    try changing the data lead that attaches to your motherboard
    Genius:
  • 1,226 Answers
Is your system still power ? if the system is working properly before u connect the new HDD. Be sure that your system or motherboard support the new HHD. if yes then, newly installed HDD sharing one cable specifically on IDE cable , the second drive should be in slave and the first one is master.( verify installation summary of the Hard drive label ) if you sure about these, then maybe memory is lessened try to fixed it by removing and installing. if not solved then update me about your system.
Posted on Dec 13, 2007
Bios no longer detects the harddrive
Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
Jan 14, 2014 | Toshiba Satellite M55-S331 Notebook
I'm trying to install MAC OS 10.6.6, but it keeps on failing. It says it can't install. The new internal harddrive is a Samsung Hm500jj 500gb,harddrive. Please help?
Be sure to use the OS installation disks that came with your system initially.
  1. You want to insert the CD or DVD that came with your computer
  2. When you get to the first screen, look for the Utility dropdown menu at the top
  3. Select erase and target the new Hard Drive
  4. Select HFS+ as the file system and check the box for OS 9 drivers if you need them
  5. Wait for a few seconds while the new drive is formatted
  6. Then select this disk for installation in the wizard and install the Operating System
Feb 26, 2011 | Samsung Spinpoint MP4 HM500JJ 500GB 7200...
Problem loading Windows XP
You need to start windows in the safe mode, press F8 at boot up.
Remove al the drivers that you've installed on you previous computer system, usualy this is is a conflict between wrong drivers and your hardware.
If you can't remove the old drivers, reinstall Windows XP, do a clean install
by booting your computer up with the Windows xp cdrom, from the Windows XP cdrom you're also able to repartionate your hard drive.
First remove the old partition(s) en make a new one, the setup does then format your harddrive, after that you're ready to install windows xp on the new partition.
Jan 19, 2010 | Microsoft Windows XP Professional
Installing secondary hard drive in a gateway 5310s
in most new cases there are extra slots for extra hard drives, but as long as the ide or sata is hooked up it should work, and you can buy hardware and rig up something ,ive tested many hard drives without hooking up hardware,
the components on the hard drive should not touch other metal
Jul 19, 2009 | Gateway 5310S PC Desktop
Hp laptop has failed to start windows
Hi , You need to run Format the drive before you install Windows.
Jan 05, 2009 | HP Pavilion ze4200 Notebook
Pavilion 525C won't start
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Az.
Sep 23, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
ACER HARD DRIVE CRASH
you can easily buy a new HDD at buy.com or newegg.com but checking the old one and installing the new one are a little harder. The drive is simply a small SATA drive and can be plugged into any newer PC. Techs use a USB adapter, but if you know something about it, installing a drive isn't that hard. You may need to enable in in BIOS though.
Installing a new one is a simple matter, but then you have to install windows, which means you'll have to boot from the CD [and HAVE a windows install CD].
Good luck either way.
Aug 15, 2008 | Acer Aspire 5102WLMi Notebook
New Harddrive
Most of the tower cabin are supprots scsi hdd please check whether it is IDE or the scsi harddrive .
Apr 28, 2008 | Gateway 505GR PC Desktop
My laptop will not boot up.
Try to put your harddrive, check on the screen if it can detect the harddrive. If it says there that ntldr is missing or if it is looking for an operating system try to install a new operating system. It like reformatting your PC.
Apr 12, 2008 | Toshiba Satellite A135-S2266 Notebook
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
