Question about Maytag Neptune MAH5500B Front Load Washer
Door wont lock so it's not spinning
My washer seems to be washing but the door never locks therefor it doesn't go through the spin cycle. It isn't draining and my clothes are soaking wet at the end of the cycle. It's 7 yrs. old and is one that has had the mold problem. Help!
  • 4 more comments
  • parkplace Dec 13, 2007
    I also have the same problem. Not locking, spinning or draining
  • Phox Dec 19, 2007
  • Stevexny Dec 25, 2007
    Older model with rotary timer, not digital.
    Lock lite doesn't lite, door doesn't lock and spin leaves clothes soaking wet.
  • Anonymous Dec 30, 2007
    First my door would not unlock then I was able to get it open. I found wet clothes in there. Now the door won't lock and the "DO" code keeps showing. HELP!
  • Anonymous Dec 02, 2008
    r11
  • Anonymous Mar 30, 2014
    fixed the drain and cleared the hoses
    but will not start, says it was in a cycle but only clicks when hit start
    President:
  • 1,314 Answers
Replace the doorlock instructions come in kit
Posted on Dec 30, 2007
Have non
Posted on Dec 03, 2008
  • 57 Answers
If that doesnt work unplug the machine and take the 5 screws out of the back of the head and check for a bad resistor on the lower left hand corner
Posted on Feb 16, 2008
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
The washing machine works fine the only thing is that the spin doesn't work, it starts but never gets to it's optimal speed. Clothes are soaking wet when the cycle ends. Our washing machine is a...
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
May 09, 2011 | EuroTech EWF150 Front Load Washer
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
After wash, clothes are soaking wet. I tried the drain and spin cycle again and while the machine hums, nothing happens. How can I take care of this?
My first one did that and it was a problem with the door lock. The door was loose and the lock light was going on but it was not really locked or not tight enough and it would spin for a minute slowly and then reverse and my clothes would still be wet.
I kept thinking I just didn't know how to use it. But they had to bring me another machine and take it back.
Hope that helps - now I love it
Jan 01, 2011 | Frigidaire ATF6000ES Front Load Washer
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Washer does not complete its cycle on any wash cycle. Error Code F 02 shows up before rinse and spin is complete. Clothes are soaking wet. What is the problem?
check the drain hose for any blockages or kinks and check to make sure water passes through it freely. it may be that it's just not emtying quick enough and therefore clothes remain wet. in a worse case scenario the pump itself could be faulty :(
Oct 27, 2008 | Whirlpool Washing Machines
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
227 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
