PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Error code 1516
By lil-pro on Dec 13, 2007
I have a improper dismount error. I wipe the hard drive clean and load windows up again and still can't load up any way except in safe mode. I think I have a registery problem. I also think it took a hit.
This is a Gateway Lap Top.
Solution #1
posted on Feb 10, 2008
Not Rated)
danasaur
Rank: Guru
Rating: 87%, 109 votes
By "took a hit" do you mean the hard drive was subjected to extreme shock, dropped, etc? Or do you mean a MBR virus?
And what software did you use to "wipe" or reformat the hard drive? Details.
Did you remove the HD and mount it externally, to erase/reformat it? Describe.
Need to know ALL this, to help you. Avoid slang, please.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Christalnet
Rank: Wiz
Rating: 84%, 84 votes
Error Message:
Error 1516: Partition improperly dismounted (EA3905EC).
Solution:
Solution #1: One possible reason for the error involves the improper setting of a “dirty” flag in a restart record in the journal file, or activity log for a given hard disk. The term flag refers to a yes/no or true/false variable or a specific quantity that indicates the current state of a program or a piece of hardware. This can happen if the system crashed, or lost power while you attempted to create or write to a hard disk.
Running CHKDSK can solve this problem. Click Start, Run, type cmd, and then click OK. The Command Prompt should appear. Next you need to indicate the disk you want to repair. Type cd C:\, and then press ENTER. If you suspect that the error is on a drive other than C:\, substitute the appropriate letter for the drive you want to check. Next, type chkdsk /f, and then press ENTER. This command checks the drive you indicated for errors, while the /f switch fixes any errors. You may need to run the utility more than once to fix all errors.
Solution #2: Another reason for this error involves a conflict with Windows 2000/XP and SMART (Self-Monitoring Analysis and Reporting Technology) error detection, which is a feature of some software utilities. To resolve the problem you’ll need to disable the SMART error detection feature. Consult the utility’s documentation for instructions on disabling the SMART error detection feature. If you can’t turn SMART error detection off, you may need to uninstall the offending utility.
Next, insert the Windows 2000 or XP installation CD into your computer’s optical drive and reboot your computer. At the Startup menu, press R to access the Recovery Console. Type chkdsk /p and press ENTER. Reboot the computer and attempt to run DriveCopy. If SMART error detection was successfully disabled, then you shouldn’t encounter the error anymore.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
thinkpad t60 battery, any recommandation?
Answer
I am in college, this would be my second computer (my current laptop is too cumbersome to carry), so... (More)
Answer
Describe your Camera Assistant Software for Toshiba Satellite Pro L300 - 164 system Problem, webcam... (More)
Answer
elo...where want to get ftec w2 v323121p driver??...can u'll help me plzz...
Answer
i cannot transfer the picture from my notebook to sony cd-rw
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
