Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
KP-51WS500 Convergence IC's replaced but green problem
I just received my new IC's today and replaced them, red and blue work great but green is oval and will not adjust with flash focus. is there any other adjustments I could make or should I just call it qwits?
  • 1 more comment
  • pitote Dec 16, 2007
    You are right one of them is open but I could only find 2 places online that sell them. They are 3.15A, 153359531 - 153359542 sony IC Link. Any suggestions.
  • pitote Dec 26, 2007
    Well I replaced the open fuseR and the green is still oval any other suggestions before i take the hammer to it.
    Thanx....
  • pitote Dec 31, 2007
    OK guys I let tv sit overnite and turned on this morning and convergance was OK. I went into service mode using my remote ant made ome final adjustments and it works great. Thanx for your help. I have the pdf schematic and can provide it for this model if someone needs it I will e-mail. this explains how to make adjustments in service mode.
Pls check fusible resistor wich supply(plus and minus) votage to convergance ic.may be one of them is open. this will solve your problem.
Gopal
Posted on Dec 13, 2007
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Thanks.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
Convergence problems w the color tubes
Press the Majic Focus button on the front. If that doesn't fix it then the convergence ICs may be bad.
Mar 31, 2010 | Sony KP-51WS500 51" Rear Projection...
Cannot converge colors on screen
This happens when convergence out ICs become defective.
Replace convergence ICs on D board to get correct picture. This qualified TV tech job.
Thanks.
Sep 06, 2009 | Sony KP-51WS500 51" Rear Projection...
TV keeps cutting off and it fades blue and green at times
sounds like the convergence ic is going bad.usually a pretty inexpensive repair
Jul 02, 2009 | Sony KP-51WS500 51" Rear Projection...
Red and green shadow lines
This 3-D problem is because to failure of convergence out ICs failure in TV and convergence ICs will be replaced.
If TV is Sony KP-51WS500 then check D board for STK392-560 and replace 02 ICs.
Required parts are available in Part Store.
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Red shadowing...
first the conv. ic's need replacement then adj.
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Kp57wv600
One of the convergence output IC's has stopped working and needs to be replaced. If the IC shorts out then it will draw too much current and possibly blow a fuse, and the set will shut down to protect itself. The IC should be replaced and the set realigned by someone with experience in convergence circuits.
Jun 20, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
