Question about Microsoft Windows Server Standard 2003 for PC
Ris how to create a RIS image and how can i configure it?
Program for two number addition by using class library.and how create library for addition of two number
Posted on Mar 12, 2009
  • 178 Answers
Creating RIS images
As we have seen, CD-based RIS images can be created throug= h the RISetup utility. Additionally, there is RIPrep.exe, a utility that allows an administrator to clone a standard corporate desktop for deployment to other systems. In this section, we will examine the RIPrep utility, and also learn about creating RIS boot disks for compatible network adapters.
RIPrep
Unlike RISetup, which only allows an administrator to depl= oy a CD-based setup of Windows 2000 Professional (even a network-based installat= ion is just a copy of the files from the CD shared on a network drive), RIPrep = can be used to deploy the operating system plus customized settings and even locally installed desktop applications. This process is not the true disk cloning that products like Norton Ghost provide, as it can only be used with Windows 2000 Professional. Additionally, RIPrep does not support multiple h= ard drives or multiple partitions on the computer that the image is being creat= ed on.
Other limitations of RIPrep include the requirement that a CD-based image that is the same version and language as the RIPrep image also exist on the RIS server, and that the target system must have the same hardware abstraction layer (HAL) as the system us= ed to create the image. By having the same HAL, that means that an image created on a single processor system cannot be installed onto a dual processor system. Since Windows 2000 does not support Alpha processors like NT 4.0, you won't have to worry about mixing up Intel (I386) and Alpha images.
While there are limitations to RIPrep, there are advantage= s to it over using RISetup to create images. Most notably, RIPrep allows an administrator to create a standard desktop image and then use RIS to deploy= it to new computers as they come in from an OEM. Additionally, reinstallation = of the operating system is much faster from an RIPrep image since the image is being applied as a copy operation to the target hard drive and not running though an actually Windows 2000 installation as would happen with a CD or <= span class=3DGramE>network-based
RISetup image.
Creating images with RIPrep
Creating an image with RIPrep is a two-step process. First= , you install and configure a computer with Windows 2000 Professional and the specific applications and settings you want to include in the image. Second, you run RIPrep.exe from the RIS server. There is an important distinction to keep clear. The RIPrep.exe utility is located on the RIS server, but is = executed from the RIS client that the image is being created on. From the client, cl= ick Start->Run and type:
\\RISserver\reminst\admin\i386\riprep.exe
If you attempt to run RIPrep.exe from a non-Windows 2000 Professional system, you receive an error message stating that the utility = will only run on Windows 2000 Professional. When you do, however, run RIPrep fro= m a valid system, the Remote Installation Preparation Wizard starts as shown in figure 13.13.
Figure 13.13 The Remote Installation Preparation Wizar= d is started by executing RIPrep.exe from a Windows 2000 Professional client com= puter
Even though you ran RIPrep.exe from one RIS server, you do= not have to necessarily copy the image you are creating to that particular serv= er. Figure 13.14 shows the next step in creating an image with RIPrep, where you choose which RIS server to copy the image to.
Figure 13.14 If you have multiple RIS servers on your network, you can choose which server should receive the image
The next step in creating the RIS image is to supply the n= ame of the installation directory on the RIS server previously chosen. Typically, = you would type the name of an existing directory only if you were replacing an existing image. If this new image will not be replacing an existing image, = type in a new directory name as shown in figure 13.15 and click next.
Figure 13.15 Supply a directory name on the RIS server= for the Remote Installation Preparation Wizard to copy the image
In our example, the image is being created for a corporate= web developer environment. For that reason, we gave the directory a descriptive name such as webdev in order to identify the image it contains on the RIS server.
In figure 13.16 we see the next step in creating an image,= which is assigning a friendly name to the image and creating the help text. The friendly name is what displays in the list of available images during the Client Installation Wizard. The help text provides an additional descriptio= n to help the user identify the correct image to use when acting as a RIS client= . In our example RIS image for a web development system, we list the applications that will be installed on the system along with the Windows 2000 Profession= al operating system as part of the imaging process.
Figure 13.16 By assigning a friendly name and help tex= t, users can identify the correct image to use during the Client Installation Wizard
If you have any programs or services running that could interfere with the imaging process, Windows 2000 will warn you. Figure 13.17 lists a number of programs and services that were running on the RIS image source workstation at the time this example image was being created. Once y= ou have closed the programs and stopped the necessary services, click next.
Figure 13.17 The Remote Installation Preparation Wizard prompts you to close any programs and services that might interfere with the imaging process.
Before beginning the actual image creation, the wizard all= ows you to review your choices. Notice in figure 13.18 that the folder name is incorrect. Initially we had created a generic folder that we had intended to use for RIS images, only to later decide to create separate subfolders for = each image. By reviewing the settings we had configured, we were able to back up through the wizard and change the folder name from RISimages to w= ebdev before starting the actual image creation.
Figure 13.18 Before starting the actual image creation= , take a moment to review your settings and ensure they are correct.
The last step, as shown in figure 13.19, is an information dialog from the Remote Installation Preparation Wizard that describes the process that is about to occur. Once you understand what is about to happen= on your system, click next to continue. You can watch the RIPrep wizard image process taking place, which will be similar to that shown in figure 13.20.<= /p> Figure 13.19 The RIPrep wizard informs you of how the = image process will take place on your system before beginning
Figure 13.20 The RIPrep wizard displays the current st= atus of the image process, showing the completed, current, and pending tasks
images created by the RIPrep wizard are stored in the same subfolder as images created during RISetup. If you took the default settings when we examined the RISetup wizard earlier in this chapter, and are using = an English language version of Windows 2000 Server, your RIS directory structu= re will be as follows:
* = \RemoteInstall\Setup\English\Image= s\win2000.pro\i386\ -- This is the default image created during the RISetup wizard earlier. The= re are subdirectories underneath i386 for this CD-based installation image, fo= r system32, templates, and uniproc.
* = \RemoteInstall\Setup\English\Image= s\webdev\i386\ -- This is the image directory we just created for our webdev image. There = is a directory called Mirror1 that appears under i386 that does not appea= r in the subdirectories of a RISetup created image.
RIPrep Files
In addition to the directory structure created, it is impo= rtant to know what files are important to the RIPrep image. These files are as follows:
* = RIPrep.log -- This ASCII text file documents the Remote Installation Preparation Wizard image process, listing any errors and relevant information that might be of troubleshooting use to an administrator.
* = Bootcode.dat -- This file is located in the \Mirror1 subdirectory of the image's i386 folder, and contains the boot sector information for the client system.
* = Imirror.dat -- This file also is located in the \Mirror1 directory, and contains installation information about the image source computer, such as the installation directory and the HAL type.
It is
Posted on Dec 13, 2007
Ris 2d s7Hello. This is Sung ah, Jo from Asianlux Company,food service equipment in Korea. My customer korean air are using this machine.VICTORY RIS-2D-S7-GDThey told me the door doesn't work well.
Hello honorable lady. Please see these links
Victory RS-2D-S7 Parts & Manuals ' Parts Town
www.partstown.com/victory/rs-2d-s7/parts
  1. Cached
  2. Similar
Find genuine OEM Victory RS-2D-S7 replacement parts at Parts Town with the largest in-stock inventory and same day shipping until 9pm ET.
Victory 50616802 COILEVAP84E21 ' Parts Town
www.partstown.com/en-ca/victory/vt50616802
  1. Cached
Find Victory 50616802 COILEVAP84E21 replacement part at Parts Town with fast same day ... Documents for RA-2D-S7-GD: ... Documents for RS-3D-S7:.
Victory Refrigeration Parts & Manuals ' Parts Town
www.partstown.com/victory/parts
  1. Cached
  2. Similar
Parts Town has the largest in-stock inventory of genuine OEM Victory Refrigeration parts with fast same day shipping until 9pm ET. Find the part you need today.
Owners Manuals - Victory Refrigeration
www.victoryrefrigeration.com/technical-service/owners-manuals
  1. Similar
A description for this result is not available because of this site's robots.txt Learn more
VICTORY RIS 2D S7 GD Google Search
Jun 22, 2017 | Refrigerators
HI I Trying to restore my ASUS EEE PC 900. It has no CD drive. I tried doing the F9 option but it does not seem to work. It keeps bringing me to the black screen where it says safe mode, start windows...
Method 1 :
  Installed Operating system with an external usb CD or DVD Rom drive.Set your laptop to boot from USB CD ROM in your BIOS.
Method 2 :
  Yoou need an PC with windows server 2000/2003 with RIS (Remote Installation server Set up plus DHCP (Dynamic Host configuration protocol) server ).Change your laptop BIOS Boot setting to boot from Network and installed as if you are installing through  normal procedure.
For more information on setting up RIS Server and DHCP.
here is the link
http://support.microsoft.com/kb/298750
http://www.windowsnetworking.com/articles_tutorials/Setting-Up-DHCP-Server-Organization.html
Dec 20, 2009 | ASUS Eee PC 900 Notebook
AXIM X3 Language
1. Download Axim X3 English (A01) setup, link from here --> http://www.slipstreamsolutions.co.uk...dates.htm#Dell
2. run the setup and make a backup ROM of youre x3, save someplace handy. I now have a file named A01-10240300GE.RIS
3. Run setup again, try to upgrade, get an error message - wrong language, etc but in that DELL folder, you now have a file named, in my case, P16R_A04080402EN.IMG
4. Open with a hex editor A01-10240300GE.RIS and copy all lines from 00 to 07
5. Open with a hex editor P16R_A04080402EN.IMG, select all lines from 00 to 07 and paste there the 7 lines from the first file, save with any name WITH .ris EXTENTION!
6. Run setup again, choose backup/restore and point to the modified .ris file. Now you have the same thing in that window, up and down side.
Do like a normal backup, DO NOT TOUCH THE PDA, THE PROCESS CAN TAKE UP TO 12 MINUTES!
The PDA restarts itself and, voila, you have axim x3 with a new language.
Jul 28, 2009 | Dell Axim X3 Pocket PC
Ris, Hold and Feature Buttons
Have you tried unplugging the set?
Try unplugging the set wait for about 15 seconds then plug the set back in... i he set will flash for a while, stop, and flash for awhile... just be patient and it will return.
Then test to see if the Feature, Rls and hold buttons work again.
PS those buttons are hard coded, and cannot be erased, they may fail, but they will not erase.
Maybe you also have a stuck button, that is affecting the set?
Jun 01, 2009 | NorStar Meridian M7310 Phone
Sir i had proablem with my mother board it dosen't support RIS
Please help me! What is a ris? Apparently we are not talking about the same thing and I want to help you because I will also learn something. But I will need certain information before I can do anything. If you help then I can help, also. Name of computer, Model number, and the MB ID, plus a description of what happened in detail. This way we can generate a model with your problem and then give you facts and not guesses. To find and verify your MB ID, which is hidden, you look for it in between the white PCI sockets, some time three and other times four PCI sockets. If by a chance they moved the information, please check around the upper right corner of the MB, around the RAM sockets. I am positive we can fix your computer...
My name is Constantin (arzconst is my nickname for the Fixya.com)
May 28, 2009 | Intel DG31PR Motherboard
RIS installation
Following links are shall be helpful to you:
http://technet.microsoft.com/en-us/library/cc766320.aspx
http://support.microsoft.com/kb/325862
Thanks for contacting Fixya
Mar 24, 2009 | FTP Software TRI-ASA2120 Router...
OPERATING SYSTEMS INSTALL WITH THE HELP OF DHCP{RIS}
the easy copy your boot cd to server service pack sp2
  1. put this on a new drive. have your 200 systems do a restart boot to new root drive that will start auto install on all systems with root drive on server. you can set install options for quite in action needed. there are some texted files on help files windows xp install check it out you can set quite afew install options it select all options your installs and restarts all 200 systems at the same time. when you restart have server del of clients boot drive restart using normal server client root drives.
please that me know if this help you thanks
good luck
Mar 21, 2009 | Computers & Internet
Need user's manual for imagerunner ir3300
Here's a link for your manual. Good luck. If this helps you plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://ris-systech2.its.yale.edu/ris/driverdownload/CanonIrSeries/Manual/Rui_g.pdf
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Sony laptop lost everything
to do that u have to install windows 2003 server on ur desktop then configure it as dhcp server then activate the ris services, and maybe ur network card didn't support boot rom, so
i recommended that u fix ur dvd drive or get an external super-dvd drive ( usb ) then do the recovery
Dec 22, 2008 | Sony PCV-RS620G PC Desktop
Remote installation Service
ok remove all roles all your server,
set up the default server roles
now set up the ris role..
Jan 23, 2008 | Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
504 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
