Question about Intel SYNTAX S651M SIS651 mATX (SYNTAX S651M SIS651) Motherboard
Computer wont boot up & makes a beeping sound?
What can i do to fix this problem?
    Problem Solver:
  • 17 Answers
Check out the link http://www.pchell.com/hardware/beepcodes.shtml
Gives you info on the different beeps which will help you diagnose your problem.
Posted on Dec 13, 2007
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Jul 11, 2013 | Seagate FreeAgent GoFlex Desk 1TB USB 3.0...
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
My computer always makes beeps sounds when i boot it up
Hi Daniel,
every computer has certain beep codes that indicate problems during the boot process. These codes are different from each manufacturer. You didn't mention which computer you are having, so I can't send you a solution. The best way is to search i.e. "HP beep codes" or "Dell9150 beep codes".
Let me know if you have any question.
Dec 18, 2012 | HEWLETT-PACKARD Hewlett Packard Techno...
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
It wont cut on keep making a beeping sound
beeping sound means that you have a bad power supply. Normally when booting your laptop, the power supply supplies enough power to boot to the operating system. You consult HP to replace your power supply in your laptop.
Oct 19, 2010 | HP OmniBook XE3 Notebook
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Oct 27, 2009 | Acer Computers & Internet
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Computer does not boot, and makes a beeping sound
check your RAM...its the main reaon for the beeping sound...check your RAM in another computer...if the beeping sound continues means replace a new one....is this cleared your problem?
Jul 10, 2009 | Computers & Internet
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Odd warning sound when trying to start computer
Beep codes from the bois normally indicate a hardware configuration or faulty hardware error. From the msi site they are using award bios. Here is a link to what the codes mean.
Listen carefully to the beeps and try to identify the problem and fix it.
From the MSI it looks as if there are very particular memory configurations make sure you have it setup correctly. Link.
Jan 29, 2009 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
Intel SYNTAX S651M SIS651 mATX (SYNTAX S651M SIS651) Motherboard Logo
124 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
