Please help me think of a way to electrically turn on and off a Dayton radiant natural gas heater.I want to connect it to a thermostat in my greenhouse. For a picture, see Graingers.com product number 6BY70
Comments:
Dec 18, 2007
- Thank you Buffalo12980. Yes, I would like a diagram of how to set it up. Some of the items you have listed are new to my vocabulary! I am not an electrician. You sound like you really know what to do. It sounds like you want me to replace the igniter? A picture would be worth a thousand words. Please send one when you have time. Please send me your email and then I will send you mine. I don't want a bunch of junk mail. Thanks again, Denis.
whoo tall order! well, since that unit uses a piezo crystal spark gap that's half the battle. go to the grainger site and find a 24 volt electrically operated solenoid for gas use. anything else won't do. next go to the white rodges web site and find a spark igniter with a flame rod flame detector 24 volt. you'll also need at least a 500va 120/24 volt transformer. a standard honeywell stat will do. I'm thinking the unit uses a millivolt generator to keep the gas valve open. you could substitute a mercury button cell to energize the pilot valve and keep the valve open. give me your email addy and I'll see if I can draw up a diagram for you.
Comments:
Dec 20, 2007
- I did some more research on your project. I wouldn't feel right if I were to bypass anything that wasn't original equipment on the heater. its a liability clause and safety. if your system burns down the garage, I would be held liable and I don't need a lawsuit now! So, I'm going to decline your request.
I used my CFM electric fireplace (Charmglow 22-inch) for about a month (flame setting only) but when...
(More)
I used my CFM electric fireplace (Charmglow 22-inch) for about a month (flame setting only) but when I turned it on this morning, it flashed on for about a second & then shut off~~now it won't turn on at all. The day before, I used the heater on the 3rd lowest setting for about 10 minutes top just to see how it worked. Why would it turn on for a second (flame setting only), then shut off & not turn on again? Did the circuit burn up? Can my local electrician take a look at it & fix it? CFM is now bankrupt and there isn't a troubleshooting customer service line anymore. Should I call in an electrician to take a look at it?
my motor for the heater and defrost in my 325i 1987 BMW went out I need to know where to replace the...
(More)
my motor for the heater and defrost in my 325i 1987 BMW went out I need to know where to replace the fuse
