Vertical 1 line
Vertical line
Check voltage supply at vertical amp ic ,if present than change vertical amp ic.Some times supply line is dameged by faulty amp ic.therefore you have to rctify supply and replace ic.Check supply line fusible resistors.
gopal
Posted on Dec 13, 2007
SOURCE:
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Tip
What is the firing order for GM 350 car?
The firing order for GM 350 car is as follows:-- 1- 8- 4- 3- 6- 5- 7- 2. -------- cylinders set in vertical way as follows:-- 8-6-4-2 in first vertical line and -------- 7-5-3-1 in second vertical line.
This will help.Thanks.
on Mar 18, 2010 | Chevrolet Chevy Cars & Trucks
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
Jul 14, 2009 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
Televison & Video Logo
551 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
