Help I dont know how to change the setting of my dvd player. The display on my tv is black and white. I've lost my manual. Please help, thank you....
I am having the same problem with an lg dvd-r model dr275 player and a phillips tv. any suggestions welcome. thanks
Posted on Feb 23, 2008
Go to menu and sub menu video .Under video option you will see video formatt,e.g Pal,NTSC.You confrim your tv standered if its pal or NTSC (this you can check at back of your tv set ,not always mention but most of them are printed)On your dvd player
you have to select same formatt as your tv .If not sure of you tv system try auto system on you player.
NB dont select progressive scan by mistake otherwise you will not see any picture on your tv if its not progressive scan tv.
If you could mention tv and dvd model and brand will be able to advise you exactly.
Posted on Dec 13, 2007
LG LCD 42' lost colour and now playing on black and white ,please help
Here is the link to a free download of the manual. Make sure all of your cables are correctly inserted and if all else fails, try a factory reset as described in the manual.
Jul 21, 2014 | LG 42LC2D 42 in. LCD HDTV
NV-VP60GC-S How do I get the color?
really? that's a settings up the menu(got a manual with this item?) and reset for defaults.
May 23, 2008 | Panasonic Multi-System Region-free...
I own a toshiba 19dv500 and am having trouble viewing a dvd, the system is working but only in black and white, no colour\???
Hello there,
A black and white picture is most often due to a faulty or incorrect RGB (red/green/blue) connection or cable.
If you are using a composite connection (red/white/yellow RCA jacks), you have probably connected the yellow plug to a socket labelled Pr/Pb, Cr/Cb, or Y - on either the DVD player or the TV - most probably the TV. The yellow needs to be connected to a socket labelled "VIDEO". If you connect this to any socket labelled Pr/Pb, Cr/Cb, or Y, you will get a black and white picture.
If you are using a component connection (red/green/blue RCA jacks), one of the plugs is either not fully inserted into the socket or is in the wrong socket. If you remove any one of the R/G/B plugs, you will get a black and white picture.
If you are using a SCART cable (UK / AUS), you may have a bent, damaged or disconnected pin.
I suggest you check and correct the connections between your DVD player and TV. If you are unable to locate the problem, please try another cable as the one you are using may be damaged. If you are still unable to locate the fault, please let me know the brand and model number of the DVD player and how it is connected to the TV. If required, I can also draw a diagram showing the correct connections.
It would also be useful to know whether this "fault" suddenly occured, or whether you have just connected the player to the TV.
Hope this helps - please let me know if you need further assistance.
Mar 03, 2011 | Toshiba Televison & Video
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Black and White
Check on the Tv sistem look on the remote for this button
Aug 23, 2008 | JVC XV-N5SL DVD Player
Can only record in black & white?
try changing your Display/ TV Connection setting under the setting menu - it may need to be set to "composite" (not RGB) if connected as displayed in the instruction manual - worked for me anyway (hope it does you).
Jan 21, 2008 | Archos 605 WiFi Digital Media Player
Having trouble setting up dvd/vcr
Slide down the cover on remote control.On the bottom right side you'll see a little switch(usually is cowered with the warning white little sticker).Slide that switch to DVD1(or DVD2 if somebody got different setting).Power up DVD/VCR combo press system menu botton,go to settings,change to DVD3(factory default)and there you go.Good luck.
Dec 25, 2007 | Televison & Video
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
No colour
Go to the setup menu. Change the output from NTSC to PAL. Should work.
Jan 22, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
