Problem in MS ACCESS
HI,
My name is Ranjit and i have a problem in MS access when i am running query it's consume 2GB space in my PC ....
and same query running in another PC it's taking 200MB space ....i have repaired the access but still not working and i hve a 2003 version but its showing 2000 why (OS 2k Professional....Office 2003 PROF)
    Sergeant:
    Champion:
  • 329 Answers
You need to upgrade first your operating system.. the new version of office 2003, is no compatible to your windows 2k.
Posted on Apr 04, 2008
I need to perform access database repair
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not Open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
Read more about Access Repair Toolbox
On:- http://www.access.repairtoolbox.com/
I tried lots of the suggestions and eventually found that this page was the most helpful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1385-%E2%80%8Bhardly-corrupted-access-2007-database
Feb 28, 2015 | Microsoft Office Access 2007 for PC
How to invoke a ms.access using parser
To parse a Text field that contains two words separated by a comma, follow these steps:
  1. Open any existing database.
  2. Create a table with the following structure: Table: Parse2Words
    Field Name: Empl
    Data Type: Text
  3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
    Callahan, Laura
    Fuller, Andrew
  4. Create the following query based on the Parse2Words table: Query: QueryTest
    Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
    Show: True
    Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
    Show: True
    NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
  5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
    John Smith
    Laura Callahan
    Andrew Fuller
Jan 08, 2011 | Microsoft Office Access 2003 (077-02871)...
Same as above really
I have fixed my problem. I realised that the Microsoft Access Database DSN did not include the *.accdb driver. I deleted the existing DSN and created a new one. This allowed me to select the ODBC driver that worked for both file types.
I cameto realise that I was only having this problem on machines that have been upgraded to excel 2007 and not on machines with full virgin installations. On install both try to create the appropriate DSN but one with the same name already exists on the machines being upgraded and the creation fails.
I hope this helps others.
Jul 18, 2009 | Microsoft Excel for PC
Using Microsoft Query to bring Access 2007 data into a spreadsheet
Try using Data > From Other Sources and select From Microsoft Query. In the Excel sheet, select the cell that you want the results to start in. Your MS Query would be pulling the data from your Access database.
May 04, 2009 | Microsoft Excel for PC
How to print only selected fields in ms access.
open your table in query, follow steps to do this...
1. open new query in access
2. locate the table
3. once table selected, select field name in selected table you only want to include in query
3. once finished selecting the field save the query
4. you can now view selected field in your table and print as well
5. you can edit the query anytime if you want to add or remove field
6. query will not affect your table since this is only query.
hope this will help you....
Oct 22, 2008 | Microsoft Access 2002 for PC
Creating a table in Ms-Access
Have you tried to name the table Tiny_tots? it might make it work. Sometimes programs are funny about letting you have spaces in the name.
Oct 04, 2008 | Microsoft Office Standard for PC
MS Access
Use a query:
SELECT "000" & [LastName] AS NewName
FROM MyTable
And export this query to the text file on your C: drive.
Jul 11, 2008 | Microsoft Office Access 2003 (077-02871)...
Ms access to excel
I do this on a routine basis.
In Access select the table or query that you want to convert to Excel.
Then File, Export,
You then will see a Dialog Box that allows you to select the format and file name.
That procedure can also be performed using Access Macros for an automated solution.
Hope this helps.
Oct 11, 2007 | Microsoft Office Standard for PC
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Computers & Internet Logo
97 people viewed this question
Alun Cox
David Payne
David Payne
