Question about Brookstone Pure-Ion (506840) Air Purifier
Air Purifier smells like chlorine
I have cleaned the filters in the dishwasher and by hand in the sink. Now when it blows air it smells like chlorine. Help!
  • treviza Nov 13, 2008
    I've done exactly the same thing, and was hoping that this is because the unit is new and the smell will go away after running for a while. I've been using for a few days now, but it still stinks.
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Posted on Nov 14, 2008
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
I need instruction on how to clean my Oreck XL.
Unplug the unit before cleaning. Wipe off the cabinet with a soft cloth and a mild non-abrasive cleanser.
To clean the electronic collector, loosen the front grill retainer screw then press in the lock and remove the grill. Pull out the collector by the tabs on the sides using both hands. Snap off the charcoal filter from the back of the collector. Then slide off the pre-filter. Spray the pre-filter and the collector with the Oreck Assail-a-Cell cleanser and then let stand for a few minutes before rinsing with water. Otherwise, soak the pre-filter and the collector in warm water (bathtub or sink) with mild dish detergent. Soak for 2-3 hours. Rinse well.
Then allow the parts to dry for completely before reassembling the air purifier. Air dry only.
Pictures to go with the Oreck XL Professional Air Purifier cleaning directions are in the manual. It is available here: http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf . See page 5.
I hope this helps.
Jul 06, 2011 | Oreck XL Professional Air Purifier
My purifier says to "perform
Krowan - You will need to remove and clean th efiler on the back, remove and clean the ceramic or glass plaques, as well as clean any dust accumulation inside the uint itself. This cam be accomplished by using canne compressed air with a straw nozzle (like you clean your computer with). Just be sure not to blow dust in your eyes.
The filter you can back flush at the kitchen sink, using warm rater. Allow it to thoroughly dry, before reinstalling it. Th e plaques can be cleaned using unscented ammonia and and old tooth brush. Rinse the thoroughly, place between 2 towel to dry completely, before reinstalling them.
That's about all you need to do. Make sure you reinstall the parts properly and that the filer is triggering the safety device.
To further help you, here's a link to the Owner's Manual, that you can download and print for future reference.
Hope this helped you.
Jun 22, 2011 | Ecoquest Fresh Air Air Purifier
We have lost our manual, could you pls. tell us how to clean the filter and or other parts, so it functions as a new one.The pure ion advanced purifier is five years old. Thanks, S.T.
I have a .pdf of the manual I can send you. I just run mine throught the dishwasher by themselves. The manual says to do that or hand wash them in the sink. Just make sure they are thoroughly dry before putting them back in.
Dec 28, 2010 | Brookstone Pure-Ion UV Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
WET DOG
Hi Teresa,
that is certainly not the smell the machine should produce :)
The smells, other then fresh air, might be 'trapped' in the filter. So washing the filter (top rack of the dishwasher works for the metal mesh filters) might do the trick.
Another trick you can try is to put the purifier on the floor, turn it on high mode (away mode) and put a box over it. Let it run for an hour or two and the smells should be gone.
Make sure you have fairly new plates, to make the machine more effective.
Dutch
Jan 11, 2009 | Ecoquest Flair Air Purifier
No smell
clean plates and blow out guts with compressed air. clean plates with mix of water and amonia!
Sep 28, 2008 | Ecoquest Flair Air Purifier
Air purifier
ozone is what you are smelling,also purchase a extra collection plate from ionic pro so the cleaned plate can dry complete.
May 10, 2008 | Ionic Pro TURBO Air Purifier
The air purifier is blowing black soot.
I had the same problem and then found that it was from burning aroma candles! I will never burn them again!
Jan 04, 2008 | Honeywell HFD-130 Air Purifier
Brookstone Pure-Ion  (506840) Air Purifier Logo
1,656 people viewed this question
Top Brookstone Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
