Question about ViewSonic VX1945WM LCD Monitor
VX1945wm not working
Have a VX1945wm viewsonic stop working today it gets power but the power light stays on bleu all the time and there is not video at all no even regular display commandas
  • Anonymous May 15, 2009
    My VX1945wm viewsonic stop working today it gets power but the power light stays on bleu all the time and there is not video at all no even regular display command, but if I turn off and on works well for 3 seconds and go dark.
Do u know how dissarm it ?
thanks!
Posted on Apr 07, 2008
Tv viewsonic n3752w no signal
have you tried to reset to factory settings.how about watching a local channel does it work just let me know so i can give further solution.
Aug 11, 2012 | ViewSonic Televison & Video
TV screen stays bleu and dos change to normal raster
Check for any loose soder terminals at the video output card. This card can be located on the neck of the picture tube, directly pluged into it.
Apr 11, 2012 | Televison & Video
Viewsonic monitor will not show screen
probly bad power supply. remove rear cover. inspect power supply for crwoned or leaking capacitors. remove and repalce with like. good uck
Dec 26, 2009 | ViewSonic VX1945WM LCD Monitor
Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
Aug 18, 2009 | Computers & Internet
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Drivers cannot be loaded...windows does not recognize monitor
I think after your crash you are missing the drivers for your graphics card and not the display. Check what kind of graphics device you have and see if you can find the drivers for that.
Sep 20, 2008 | ViewSonic VX1945WM LCD Monitor
Screen goes white after 12 seconds
Per the first hit on Google for 'viewsonic fades white', http://forums.worldofwarcraft.com/thread.html;jsessionid=A68BB7FE4AF6EC93EB730E8588C865A2?topicId=4064461903&sid=1
(which you should go on and read in another tab,) you need to contact Viewsonic about an inverter board (for the CCFL backlight) or switching your backlight to LED while spoofing the INVERTER_OK signal to keep the display from giving up as it does.
So...this should be a hint that you should respect others' time (or be moved to increase usability) better by searching for cures in similar Viewsonic monitors, and of course checking the obvious search terms.  Viewsonic evidently has a nifty knowledge base available for all on the web, so that one would be a nifty surprise.
Aug 18, 2008 | ViewSonic VX1945WM LCD Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
Viewsonic Monitor sound problem
Hi check the sound cable hasn't fallen out or come loose from the back of the monitor. After this reinstall the drivers for the monitor you will be able to download them from viewsonic if still not working then the speaker jack or speakers are faulty.
Hope this helps
Thanks J
Jan 20, 2008 | Computers & Internet
ViewSonic VX1945WM LCD Monitor Logo
182 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
