Question about StarTech.com VGA to NTSC/PAL PC to TV Video Converter (VGA2NTSC) Video Capture
Vga2ntsc problem i gave my vga2ntsc adapter a static shock, now it displays everything in a low resolution (as if i was running my computer in safe mode). i tried different computers, and all possible button combinations but to no avail. i also tried changing computer video output settings, but nothing works. any ideas?
  • 3 Answers
To choose a good product from a good vendor is important.
But one thing for sure the image quality will a little short of the original VGA.
You can try our VGA TO AV Video S-video Converter(AV3500)
Details: http://www.gonbes.com/en/Gonbes-AV-3500.html
Technical Support: Mr. Wu
E-mail:sandy@gonbes.com
TEL Phone:0086-755-82053232 FAX:0086-755-82053969
ADD:NO.4W Suotaike Building, Bagua 4 Road,Futian Shenzhen, Guangdong 518029 China
Posted on Jul 31, 2010
  • 34 Answers
Static shocked could be dangerous for your devise they may have blown down you IC(integrated cuircuit) or any other component so please it better to go to a vendor then self experimenting.. or claim your warrenty
Posted on Dec 15, 2007
Dell 780
This is not a GPO issue. The problem is that all Windows will attempt to set the new resolution and a fail-safe is that if you do not click the Keep Changes button after thirty seconds it switches back to the old settings. This ensures that if you set the resolution to a range the monitor or display adapter can't handle that you don't get 'stuck' with a blank screen.
Check that the display adapter in the Dell 780 can handle a resolution of 1280x1024 and that the monitor can also handle this resolution.
Jun 27, 2012 | Computers & Internet
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
I adjusted resolution on my HP notebook now when I turn on cant see screen. Please help
Hi Jess,
Boot the computer in SAFE MODE by Restarting the computer, and the moment its on keep tapping the F8 key untill you see a screen saying "Windows Advanced option...".
1. Select Safe Mode using the keyboard arrow key and hit enter.
2. This will load all basic drivers to start safe mode operation.
3. Go to Display Properties (WindowsXP) or Display Settings (Windows Vista) by right click on empty blank space on Desktop, then select Properties(Windows XP) or Personalize(Windows Vista).
4. Then change the resolution by sliding the Low to High slider bar. Do not press "OK" or "Apply" at this time.
5. Instead, click on Advanced Settings, and then click OK. Windows in Safe Mode will change the screen resolution according to new settings, and prompt a "Monitor Settings" dialog box prompting that desktop has been reconfigured, with countdown timer. Click on Yes to keep the new settings.
6. Alternatively, simply click on Advanced, go to Adapter tab, then click on List All Mode. Select a mode with screen resolution size and color mode that you prefer, and click on OK. Windows will apply the new resolution size and color quality on Safe Mode too.
Regards
Riztech
Oct 17, 2010 | HP Mini 1000 Netbook
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Like a lot of others. Black screen after 3 secs . Switch off, restart, a few secs off again any ideas ????
Your computer's video adapter may be asking for a resolution that is not supported by the monitor.
Start up in Safe Mode (Google it if you don't know what this is)
Change your display resolution to a low setting like 800x600.
Restart the computer and let it start up in Normal Mode.
The monitor should work now and you can change to a higher resolution so long as it is supported by the monitor.
Apr 17, 2010 | Computers & Internet
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
Monitor problem: not optimum mode recommended mode: 1280x1024 60 hz ? cannot click on screen. Samsung model 913T s
It appears your display adapter is set to a different refresh frequency or resolution,
either accidentally or due to some power glitch.
If you cannot set the resolution because this message is preventing you from getting to the
display settings window, try rebooting your PC in Safe Mode. It'll take a while longer
than usual, but when you're finally running, try setting your display adapter to the
1280x1024 60Hz settings. This is available under "Advanced->Adapter->List all modes".
To reboot in safe mode, try pressing the PF8 keys repeatedly after the POST messages
disappear just after turning the power on. This only works if this key is enabled to
operate from the BIOS settings.
To get to the BIOS setup, Look at the first messages displayed on your screen indicating what key to press. It's usually the Delete or PF2 key, but different BIOS manufacturers use different keys.
Once inside the BIOS setup, find the way to enable the PF8, PF9, PF10, keys. Save your
settings and reboot.
Now you may try PF8 again to go to Safe Mode.
Good Luck!
Aug 19, 2009 | Computers & Internet
Monitor screen stuck at input not supportedhow do I go back ?
Assuming you have not changed the connection to your monitor (from VGA to DVI signal, for example), or that you have not messed around with the display settings, further below may be the situation. Else, you need to access your LCD menu and choose the other type of input SIGNAL.
It appears your display adapter is set to a different refresh frequency or resolution, either accidentally or due to some power glitch.
If you cannot set the resolution because this message is preventing you from getting to the display settings window, try rebooting your PC in Safe Mode. It'll take a while longer than usual, but when you're finally running, try setting your display adapter to a resolution of 800 x 600 pixels at 60Hz settings. This is available under "Advanced->Adapter->List all modes".
To reboot in safe mode, try pressing the PF8 keys repeatedly after the POST messages disappear just after turning the power on. This only works if this key is enabled to operate from the BIOS settings.
Once inside the BIOS setup, find the way to enable the PF8, PF9, PF10, etc keys. Save your settings and reboot.
If your PC is Ok, then you may try setting your monitor to a higher resolution, taking care not to exceed the maximum values, as stated on the user's manual.
Good Luck!
Aug 19, 2009 | HP Computers & Internet
Everything on the screen is enlarged?
You should be able to reset you screen resolution by clicking on Display inside the control panel. Go to the Settings tab once the display properties window opens and look for the screen resolution area that allows you to adjust the resolution. If its set at the low end, move it over to the high end and press Apply to test out the new sizing
Mar 26, 2009 | HP Pavilion dv6000z Notebook
StarTech.com VGA to NTSC/PAL PC to TV Video Converter (VGA2NTSC) Video Capture Logo
90 people viewed this question
Top StarTech.com Televison & Video Experts
Marvin
Marvin
Are you a StarTech.com Televison and Video Expert? Answer questions, earn points and help others
