Question about OKI C5200n Laser Printer
Printer My printer is printing but the color does't even. There is a band about 3cm wide from top to bottom which is lighter than other area of a page. What should I do? Thank you for your help!
  • OKI Master
  • 1,113 Answers
Print a full page of each of the four colours to isolate which drum/drums are causing your fault, replace it with new.
Disconnect each toner from the drum to see that each drums toner slit is full to the top with toner, make sure you have cleaned the led heads (4 long thin bits on ceiling of printer)
Posted on Dec 13, 2007
  • Soulvisitor
    Soulvisitor Dec 20, 2007
    ?and.....thanks for rating
Light wide strips printing on page.
have u checked the itb, image transfer belt.
or transfer roller
Sep 17, 2015 | Samsung CLP315 Color Laser Printer
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
My Ricoh Aficio SP C811DN-DL Printer smudges bottom of the page each time I print. It's a 3cm wide stripe of colourful smudges running across the bottom of page.
Transfer belt cleaning unit. The transfer unit is above the drums and the cleaner is on the left side. Remove it and I would bet you see a similar band as what your seeing on your prints. You can try wiping of the cleaning blade in the unit or you may have to replace it.
Dec 23, 2009 | Ricoh Aficio SP C811DN-DL Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Lighter bands across copy using Canon F 132500 copier
Open the flap to expose copy platen and press print you should get a flat even black
if you get the white bands do the following:
Clean the corona wires open the cover pull out the sliding charge wires and clean with q tio and acoho or a pencil erasure
If that does not work remove top glass and clean mirror and bottom of glass
Dec 24, 2008 | Office Equipment & Supplies
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Colors become lighter toward end of print
yes, the original image may have been released too soon from the scan image input. check the original and see if the color is lighter. flip the image bottom to top and run 1 copy to see if the problem is still there in that location. if it is, then you have a backlight burnout occurring or dirty glass area.
Jun 21, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp Laserjet printer
a vertical stripe that is consistent top to bottom could be a laser issue, it has prisms and lenses that could be dirty or even a bit of paper stuck covering the laser light window. Dig into it and look for any debris and clean the lenses.
May 22, 2008 | HP LaserJet 4 plus Printer
Toner is skipping in same part of the page
you have a weak photo drum or dirty corona wire take drum assy out and spray metal grid above drum suface with canned air until free of toner dust(take outside to prevent toner dust from getting on carpet or household ) items.
After cleaning reinstall drum and run printer.
Jan 07, 2008 | Konica Minolta magicolor 2430 DL Laser...
OKI C5200n Laser Printer Logo
108 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
