Question about Omisys 333F (256 MB) MP3 Player
Importing music I'm new to this mp3 player stuff how do I get the music on my mp3 player?The manual is no help what so ever...Please help
0 characters
1 Points
My sakar dicital music palyer voice recorder wont play the music i downloaded onto the file
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :-
Apr 06, 2012 | MP3 & Digital Media Players
I need a manual please. I have a Philips GoGear MP3 Player SA2RGA02 and I can't understand how to download music from my computer onto the MP3 Player successfully. Please help. I need the manual...
I cannot hrlp you with a manual BUT here are some instructions -
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
Click on this link for instruction on converting music files to mp3 file format:- When you connect the MP3 player to yourcomputer and the computer detect the player as an external storage device or aRemoval disk, you can then view the folder on your MP3 player. Open the musicfolder and create a new folder on the player exactly the same way you create afolder on your computer's hard drive. To organise your music, make a foldername with the name of the music album and place the album's MP3 files in thisfolder.
You will then be able to select the music you want to play by the music albumfolder.
May 30, 2011 | Philips GoGear SA1350 MP3 Player
How do i download music to icarly music player?
Download its soft wear or drag stuff to it like its A juump drive
Feb 08, 2011 | Imation iCarly MP3 Player
How to put music from my laptop to my zune 30gb
Importing Content to Zune Software
Zune software provides several options to import content. By default, Zune software automatically imports content that is downloaded to the following folders:
  • My Music
  • My Videos
  • My Pictures
Zune software monitors these folders for the current user as well as the folders designated for All Users. When content is downloaded to any of these folders, it is automatically imported to the Zune media library.
Zune users can also add a new folder to the list of folders that Zune software monitors, or they can manually drag and drop content from any folder to the Zune media library.
download zune software for which you can sync songs
Jun 06, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Won't Import MP3's From Computer
Try this...Push a pin into the reset hole at the bottom of the player while at the same time holding down the play and power buttons. Next on the recovery screen that shows up, run the ":clean-ip" function. Then try again to import the music files.
Aug 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
Downloading lime wire to mp3
depending on what software you use to synchronize songs unto your mp3 player, you'll need to import the songs that you download from limewire into the program you use.
Jun 28, 2008 | SanDisk Sansa Clip MP3 Player
MuVo V100 mp3 player
after u downlaod the song u want go to library then go to explore then stick ur songs somewhere in my music i make folders tho so it will be more organized. then go to import files in your creative media source and click on the stuff u want out off my music and import it. last just go to the browse section of the media player and click on ur mp3 and transfer it all over
Feb 24, 2008 | Creative Labs Muvo V100 MP3 Player
Downloading music
Use a download program or rip media to your computer, use the music converter included or drag your media files to your mp3 player folder found in My Computer.
this should all be in the manual though.
Dec 25, 2007 | Philips GOGEAR SA6045 MP3 Player
File error
Try a reset and see if it corrects itself. hit menu, settings, scroll to reset all, select yes. This won't delete any files, but it should clear up the song transfer problem. If that doesn't work you may have to reformat the device which will erase all data on it. But then you can start fresh again.
Jul 31, 2007 | SanDisk Sansa e250 MP3 Player
Not enough room for music database please free 4 mb
format and then update the firmware of the player. 1. Open "My Computer." 2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu. 3. Press "Start." 4. You will receive a warning that the format process will erase all data on your device. IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Agree to the warning. 5. The format will complete. Close the format window and your player should be ready to use. After the format, let us install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa m200: PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update. To set your player in MSC mode, let us do the following: 1. When the player is turned on, press the ?Menu? button. 2. Navigate to the ?Settings? menu. 3. Navigate to ?USB?. 4. Under the ?USB? menu, switch from ?Auto Detect? to ?MSC?. After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read ?USB Connected? and ?MSC.?
Jul 04, 2006 | SanDisk Sansa m230 MP3 Player
Omisys 333F (256 MB) MP3 Player Logo
18 people viewed this question
Top Omisys MP3 & Digital Media Players Experts
Are you an Omisys MP3 and Digital Media Player Expert? Answer questions, earn points and help others
