Question about Lexmark X7170 All-In-One InkJet Printer
Paper keeps jamimg
The printer was working fine i printed a bunch of cd covers with it so thats a liitle bigger stock than normal now when i tryed to print regular or transfer stock it keeps telling me there is a papper jam and remove it so i open the back and remove the paper it is not wrinkled or damaged in any way or caught on anything so i try again an then it prints somthing fine one sheet perfect then jam jam jam it doesnt seem to be feeding the paper through for some reasone any hints ??
  • Lexmark Master
  • 1,113 Answers
Clean all the feed rollers with a slightly damp soft cloth and see what happens, ensure if applicable on your model that media/paper type is set to correct format for what you are printing ie card stock / heavy, then throw it in the bin after releasing ones frustration on it.
Posted on Dec 13, 2007
U break it and put it in the dustbin
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
I have an Epson R 300. It worked fine with my PC. I recently got a new I-Mac and I cannot print CD/DVD's. I have the Epson "Print CD" application loaded but when I try to print on a DVD I keep getting an...
If you are using a leopard operating system, you have to install easyprint. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26322&prodoid=37368458&infoType=Downloads&platform=Macintosh,
Trash / re-install epson print cd.
There is a work around for that. Please contact epson.
Apr 30, 2009 | Epson Stylus Color 300 InkJet Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper pulls to right and bunches up when loading
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Photos print green Photos print green on photo paper, but fine on regular paper stock. I have the HP 7960 same problem...anybody know how to fix this? Is there a type of photopaper that won't react this...
In the printer settings choose the type of paper, card, or the various photo papers that are listed. This must be selected to get the best quality for each project you are doing weather it is just normal text or quality photos, the both require different print settings. Usually by using the automatic setting does handle most settings but dont bank on it.
Sep 24, 2008 | HP PhotoSmart 7760 InkJet Printer
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I am trying to print double-sided copy on card stock
HI there sounds like there is a blockage in the duplex area that is not holding any sensors down. Check the duplex area for torn paper, failing this it maybe a sensor problem which will then need a engineer.
Hope this helps
Thanks J
Jan 30, 2008 | Brother HL 5250DN Laser Printer
Xante Ilumina Digital Color
it is a fact of digital print that toner scatter will apear ever so slightly. But it is noticable much more on glossy stock, as there is a high reflectivity, and no micro valleys in surface texture to loose it in..having said that...glossy stock is very difficult to print on with the Ilumina..even on label setting/ auto select for weight and Media switch on(this is the best I have been able to achieve)
Sep 26, 2007 | Xante Ilumina Digital Color Press Printer
Lexmark X7170 All-In-One InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
