SOURCE: Parrot Minikit
Hi
I found the reset hole and i reset it and it work properly after...
but no where to be found in your book.
Thank you
Bernilap
SOURCE: Red light on and wont work, wont even turn off
Try hitting the parrot reset on the back of the unit. Small hole that you can insert a paperclip into reset the unit.
SOURCE: Green and Red Lights on my Parrot minikit slim/chic are flashing
Spoke with Parrot, was told that the batt had been left to run to low and I had tried to use it.
let the batt run right out and all will be ok.
I know put on charge veryday and have to had the problem again
SOURCE: Parrot minikit slim frozen
Hey people! Read the full owners manual on the web.
Press the jog wheel and reset button at the back at the same time.
It resets itself.
By the way, I've thorn down every single piece of the slim kit, I unscrewed about 8 screws, and I suggest you do not do the same ever.The soft pad is self glued and now it does not stick back as before.
