Question about EliteGroup 755-A (ECS 755-A) Motherboard
System booth i bought a new DDR 400 ,512 Mb ram and install it on my pc, when i turned on the my pc, the booth screen bios ok, then when windows is loading up on the screen, it stops and black screen shows on the monitor. It did not load the main windows for my OS..when i restart my pc, I load it on the safe mode, then the pc starts and did not show the black screen..I encounter this problem many times, sometimes my pc booth normally but sometyms not.My motherboard is ECS 755- A2..Is there a problem wid my board..i install the new memory at my frends PC  and it starts normally.
    Champion:
  • 209 Answers
The ram memory might not be compatible from your motherboard, you should have find it on the list of your motherboard manual. the manual have the list of memory cards' qualified brand. likewise, try to install this to ther slot if the problem still occurs then you may return to your vendor and inform them about the specs and kind of your motherboard and the problem you are encountering so that they will give you the right memory card to use. you can also ugrade your bios thru the internet so that you don't need to return this item.
Posted on Dec 13, 2007
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Ram not working with motherboard
Hi
Check if your motherboard only supports only dual channel interleaved memory from the manual because it might be the main issue of your problem. Also DO NOT plug in the 512 MB ram you have over there. If it is ok to have one Slot empty then there should be no reason why it should not POST properly. Before jumping to conclusions that the RAM is faulty. Make sure that you REMOVE any overclocking you might have on the system. Some RAM won't post wihen the CPU clock and multiplier are not standard. Also it could help if you load FAIL SAFE settings in the BIOS until you determine the proper cause of the problem.
Hope that this helps :) (please rate thanks)
Jan 07, 2009 | Intel D865GBF Motherboard
MEMORY UPGRADE
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 28, 2008 | Computers & Internet
P4vmm2 wont boot up
Disconnect power cord, remove the button cell battery, press the power button to dissipate any stray volts, replace button cell, plug in cord and re-boot, this will reset bios to default settings.
You will get a check sum error so enter bios to re-set date time and other settings.
May 13, 2008 | EliteGroup P4VMM2 Motherboard
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
Installing new memory
ya cuse old moduel is slower hu drops speed back to 2700 and not 3200 ? corect its in bios settings re auto detect ram set to automatic config itself what brand ram u buy sum fox commm bords very picky on low denstiy and hi density styles ok low beter more compatble 38 bucks 1 gb on ebay ddr 400 i run 3 of those in my gigybyte moby and it loweres my ram spee dto 333mhz not 400 when i use all the slots up cheak your bios settings let me know name brand usally the pp who make it call them tell thenm and ask for time settings to be best with your mobo ok if they have great tech support if not tell me models
Jan 17, 2008 | Foxconn 760GXK8MC-RS Motherboard
P5RD1-VM Missing RAM
ok..here's what you gonna do, turn off your computer..open your system unit and reset your memory card then turn it on again.ok?
If still doesn't work..just let me know here..
Jan 15, 2008 | ASUS P5RD1-VM Motherboard
EliteGroup 755-A (ECS 755-A) Motherboard Logo
113 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
