1) check and or clean you vent..
2) check air coming out of the vent...
a) if no air coming out or little amout of air ... check blower wheel ( remove toe panel. then remove blower cover.) wheel should be clean and clear ...
PS. there is a reset button on the back panel... black button about center..
hope it helps if NOT let me know more about your problem...
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
