Question about JVC AV-36320 36" TV
I dont have a remote ! how do i set the TV to the dvd player?
How do i set the channel to wacth movies without remote
  • 3 Answers
There should be a set of controls on the front of the tv that you can change the channels and settings from there
Posted on Dec 13, 2007
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Apr 24, 2008 | Disney DT1300-P 13" TV
Swiching from tv to playing video
sorry. you cannot switch to video mode without the remotes
Feb 21, 2008 | Disney Princess MCP DVD2050P DVD Player
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
JVC AV-36320 36" TV Logo
108 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
