Question about Lasko 5365 Ceramic Compact Heater
Won't shut off when reaching preset temp
The heater will not react to the temperature setting and shut off when the preset temp is reached. It had been working great and suddenly developed this problem.
temperature setting problem
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Posted on Mar 25, 2008
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
Is it normal for my furnace to have burner cycle once or twice
That sounds normal. When the bonnet reaches a preset temperature the burner turns off then when it cools down a bit the burner turns back on. Clean filters etc will help to keep the burner on longer in a cycle.
Aug 24, 2014 | Heating & Cooling
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
Caravan does't reach operating temperature
No one ever said new means good. Try another thermostat. Make sure it is the recommended temp for the vehicle. I would spend the extra money to buy a dealer thermostat. What controls temp is restriction of flow thru the system until a set temperature is reached and the thermostat opens. Has to be a thermostat.
Dec 31, 2013 | Dodge Caravan Cars & Trucks
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
Temp doesn't shut down when preset temp reached. Have to do it myself. Set it for 62 for example, won't come on till I set it to maybe 70. Try to set the temp to maybe 65, doesn't shut down till we...
This is normal. It will only turn on when the temperature set is below the ambient temperature in the area around the thermostat.
Your problem may be the location of the thermostat is not ideal form the areas you are heating. this usually cause the temperature in areas vary from the thermostat to the point wher relocation of the thermostat is sometimes the best resolution.
this is often the case wher ther are multiple heating zines in a building, and one or more zones interfere with the thermostat of others,
but it also happen in single zone heating systems too.
Jan 30, 2010 | DeLonghi DCH4120 SafeHeat Ceramic Compact...
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Sounds like a thermostat problem or a short in the wire. Can you give us more info like is it gas or electric and model numbers will help.
Thanks.
Oct 11, 2007 | Heating & Cooling
Lasko 5365 Ceramic Compact Heater Logo
414 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
