SOURCE: when connected to charger it says 'CHARGER NOT SUPPORTED'
clean the battery contact inside + battery
SOURCE: charging the phone
jry230 - the charging port needs to be resolder back on to the board.
ROBBIE1156 - have the charging port replaced on the phone.
SOURCE: iMac bluetooth mouse won't move cursor
Did you seperately setup the mouse? Even if you have, go into the Bluetooth preferences under System Preferences. Select the mouse & delete it. Setup a "New Bluetooth Device" and select "Mouse." Be sure to press the Reset button for 2-3 seconds to get the mouse into "Discoverable" mode. Your Mac will then setup the mouse automatically.
If this does not work, the Bluetooth chip in the mouse may be defective.
SOURCE: When using the lens on my Canon Digital EOS Rebel
try to use another lens.
the problem is still,i think malfunction is on the body.
If solved,,,,,error is on the lens.
k.
